[Mapserver-users] colouring problems
Lars Holm Loldrup LLO at CARLBRO.DK
Wed Dec 10 06:02:25 EST 2003
It seems like the same BUG that I submitted:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=468
Regards Lars Loldrup.
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Wednesday, December 10, 2003 6:01 AM
To: bartvde at xs4all.nl
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] colouring problems
Bart van den Eijnden wrote:
> Hi Frank,
> the strange thing is that I also had this problem when cascading images
> coming from ArcIMS.
> We tried both PNG 8 bit and PNG 24 bit output from ArcIMS, and png24
> output in Mapserver. Then also these problems arose.
> In that case (png24 output in Mapserver), Mapserver could not run out of
> colours could it?
Bart,
With 24bit png output MapServer should absolutely not run out of colors.
If you can reproduce this in a form that can be easiliy bundled up then
please submit a bug report.
> There is no way to define a colour table in the map file for example?
I am not aware of a clean way.  One not-so-clean way is the dummy layer
with a class for each color you want to include.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
