[Mapserver-users] Config for Antialiased Lines
Steve Lime steve.lime at dnr.state.mn.us
Wed Dec 10 15:58:17 EST 2003
Antialiasing is only available with solid, single pixel lines. It's a
limitation of GD (or my reading of the GD manuals). GD does not support
the drawing brushed lines or styled lines with antialiasing, or at least
I've not found it.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Paul Dugas" <Paul at DugasEnterprises.com> 12/10/2003 2:10:27 PM >>>
Hi all,
I'm using a nightly shapshot from back on Nov-18 and gd-2.0.15 on a
RedHat-9 machine.  I'm using 'shp2img' to generate PNG24 images that
are
used by other marts of my system (no webserver, CGIs, or MapScript).
I'm
trying to figure out how to get my map-file setup to render using GD's
ability to draw antialiased lines and am quite stumped.  I ended up
hacking 'mapgd.c' to force it to always pass gdAntiAliased to the
imagePolyline() routine but I'd really like to figure out why my
configs
arent' doing the trick.  The relevant (I think) parts of the config
are:
  MAP
    SYMBOL
      NAME 'smooth'
      TYPE ELLIPSE
      POINTS 1 1 END
      FILLED TRUE
      ANTIALIAS TRUE
    END
    LAYER
      NAME Interstates
      TYPE LINE
      CLASS
        COLOR 34 86 136
        STYLE
          SYMBOL "smooth"
          ANTIALIAS TRUE
        END
      END
    END
  END
I can't seem to get the antialiasing turned on.  I've tried to follow
the
'mapfile.c' and 'mapsymbol.c' files to understand how the parser works
but
I quickly got lost.  I could figure it out, I'm sure, if I spent a bit
more time on it but reverse-engineering the proper config file from
the
source code seems strange.  Is there updated documentation somewhere
that
might help?
While we're on the topic of the config file, has anyone considered
moving
to a XML file instead?  I've dome this with many of my systems as
libxml
now ships with my target platforms (Solaris and RedHat).  The parser
library is simple to use and the resulting in-memory tree is simple to
iterate through.  I believe a DTD/schema validator is also included in
the
library so you could rely on it to parse and validate the config
allowing
your code to assume the resulting structure is okay.  Just a thought.
Last thought, I'm using 'shp2img' in the build scripts fo my program.
The
map-file I pass it has the size of the resulting image in it but I
can't
override it on the command line as I can do with the extents.  Would it
be
possible to do one of two things:
  - add argument to 'shp2img' to specify the desired image size
  - have 'shp2img' read its map-file from STDIN
Without either of these, I generate a temporary map-file from a
template
replacing the "SIZE" values.  Kind of messy to someone as retentive as
I
am.
Thanks in advance,
Paul
Paul A. Dugas <paul at dugasenterprises.com>              phone:
404.932.1355
Dugas Enterprises, LLC                                   fax:
770.516.4841
1711 Indian Ridge Drive, Woodstock, GA 30189 USA
On-site at Georgia DOT, TMCx1015, 404.635.8013,
paul.dugas at dot.state.ga.us
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
