[Mapserver-users] layer not drawn in utm projection
Debbie Pagurek pagurekd at agr.gc.ca
Thu Dec 11 10:31:36 EST 2003
This is a MIME message. If you are reading this text, you may want to
consider changing to a mail reader or gateway that understands how to
properly handle MIME multipart messages.
--=_CE9024CC.204102DA
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: quoted-printable
Please post your mapfile to the list so we can try to see where the
problem might be.
D. Pagurek
>>> "niklas w=F6rmann" <nwoe at privat.utfors.se> 12/11/03 10:07AM >>>
Hi!
i think i have found a bug.
i have my mapfile set up so it will render an ocean rectangle as a
bottom
layer, and then the land layers on top of this.
( i know, you can use imagecolor for this too, but for various reasons i
need the rectangle to be there)
the layer shows up fine when using proj=3Dlatlong
but will not show up when using UTM.
i have tried outputting both jpg and swf, and neither one shows the
ocean
rectangle when using proj=3Dutm.
regards
niklas woermann
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: text/html; charset=ISO-8859-1
Content-Transfer-Encoding: 8bit
Content-Description: HTML
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="MSHTML 6.00.2800.1276" name=GENERATOR></HEAD>
<BODY style="MARGIN-TOP: 2px; FONT: 10pt Arial; MARGIN-LEFT: 2px">
<DIV>Please post your mapfile&nbsp;to the list so we can try to see where the
problem might be.</DIV>
<DIV>&nbsp;</DIV>
<DIV>D. Pagurek</DIV>
<DIV><BR><BR>&gt;&gt;&gt; "niklas wörmann" &lt;nwoe at privat.utfors.se&gt;
12/11/03 10:07AM &gt;&gt;&gt;<BR>Hi!<BR>i think i have found a bug.<BR><BR>i
bottom<BR>layer, and then the land layers on top of this.<BR>( i know, you can
use imagecolor for this too, but for various reasons i<BR>need the rectangle to
be there)<BR><BR>the layer shows up fine when using proj=latlong<BR>but will not
show up when using UTM.<BR>i have tried outputting both jpg and swf, and neither
one shows the ocean<BR>rectangle when using
proj=utm.<BR><BR><BR>regards<BR>niklas
woermann<BR><BR><BR><BR><BR><BR><BR><BR>_______________________________________________<BR>Mapserver-users
mailing list<BR>Mapserver-users at lists.gis.umn.edu<BR><A
href="http://lists.gis.umn.edu/mailman/listinfo/mapserver-users">http://lists.gis.umn.edu/mailman/listinfo/mapserver-users</A><BR></DIV></BODY></HTML>
--=_CE9024CC.204102DA--
