[Mapserver-users] FEATURENQUERY problem
Frank Koormann
frank.koormann at intevation.de
Mon Dec 15 04:19:59 EST 2003
* pete skywalker <pete_sky at hotmail.com> [031212 19:12]:
> Frank,
> Thanks for your helpful answer & your suggestion.
> Regarding to featurequery function, this function use img.x and img.y to
> select the feature of slayer to be used for query, my understand is that
> right?
Yes. As an alternative you may consider the ITEMFEATUREQUERY, which
identifies the feature from slayer by attribute.
> Last question, can i set buffer distance from feature of slayer that used
> for query?
The TOLERANCE can be used for this.
Regards,
Frank
Frank Koormann <frank.koormann at intevation.de>
Professional Service around Free Software (http://intevation.net/)
FreeGIS Project (http://freegis.org/)
