[Mapserver-users] php mapscript ms_newLayerObject and no mapfile
Daniel Morissette morissette at dmsolutions.ca
Mon Dec 15 10:05:21 EST 2003
aaronkoning at shaw.ca wrote:
> -----HTML/MAPSCRIPT---------
> <?php
> dl('php_mapscript.so');
> $map_path="/var/www/html/test/mapscript/t/";
> $map = ms_newMapObj($map_path."europe.map");
> $layer = ms_newLayerObj($map);
> $layer->set("name","world");
> $layer->set("type","MS_LAYER_POLYGON");
> $layer->set("status","MS_ON");
> $layer->set("data","europe");
The constants in the statements above should *not* be inside quotes. You
should use:
$layer->set("type", MS_LAYER_POLYGON );
$layer->set("status", MS_ON );
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
