[Mapserver-users] Different instances to the same map II
Steve Lime
steve.lime at dnr.state.mn.us
Mon Dec 15 15:53:57 EST 2003
Not really. You can change extents, layer lists and so on to add multiple maps to a page. Typically you use a query to get at the necessary spatial or attributes and then build a series of maps from that information. Here's an example. Only one map but it's generated based on the attributes of the queried feature. One could easily add inset maps for Landsat images and quads.
http://www.dnr.state.mn.us/maps/compass.html?map=COMPASS_MAPFILE&mode=indexquery&shapeindex=1786&qlayer=pwa_query
Just about anything is possible.
Steve
>>> Bob Basques <bob.basques at ci.stpaul.mn.us> 12/15/2003 1:41:30 PM >>>
Steve Lime wrote:
>You can cram as many maps on one page as you like. Just alter parameters and use mode=map within img tags to generate them.
>Steve
Really, that's a new one, I figured this was a pretty big deal to
configure, hmmm, some possibilities are coming to mind.
bobb
>>>>Vladimir Guzmán <vguzman at maintask.com> 12/11/2003 10:24:24 AM >>>
>Juan Carlos:
>I can see you are using mapserver CGI.
>I don't know if this is possible to do with CGI, we use PHP-mapscript,
>which give us much more power to deal with this kind of things.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
