[Mapserver-users] Empty screen with .tab file?
Hugo Nathaniel Rodrigues hugo at pbh.gov.br
Tue Dec 16 11:17:48 EST 2003
yes, im using that php_mapscript (file
php_mapscript_4.1-php-4.3.2-Oct72003.zip), maybe is this? maybe i need to
try other version? (wich this one i had too many problems with path names,
but i solve it all using the complete DOS path).
cheers
Hugo Rodrigues
Analista/Consultor
SSSS - Prodabel
----- Original Message -----
To: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
Sent: Tuesday, December 16, 2003 2:08 PM
Subject: Re: [Mapserver-users] Empty screen with .tab file?
> Hugo,
> I agree. We have the same conclusion. We have the same error... Are you
> using php_mapscript41.dll?
> The ogrinfo.exe comes from openev_fw package. you should be able to find
it
> in the mapserver download section.
> From: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
> To: "Denis Louvegnies" <denis at louvegnies.com>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Tuesday, December 16, 2003 4:58 PM
> > i just tested one thing:
> > i commented the lines:
> > CONNECTIONTYPE OGR
> > CONNECTION "./distrito.tab"
> > and with that, i received a blank screen, now im sure (again) that the
> > problem in anything with the ogr connection.
> > Hugo Rodrigues
> > Analista/Consultor
> > SSSS - Prodabel
> > From: "Denis Louvegnies" <denis at louvegnies.com>
> > Sent: Tuesday, December 16, 2003 1:36 PM
> > > one END is missing at the end of your bhdistritos.map file
> > > Denis
> > > Sent: Tuesday, December 16, 2003 4:11 PM
> > > > here are my mapinfo files.
> > > > i receive all warnings and fatal errors, and cant open it :
> > > > Warning: [MapServer Error]: msLoadMap(): in c:\arquivos de
> > > programas\apache
> > > > group\apache\htdocs\testes basicos\mapabasico.phtml on line 7
> > > > Warning: Failed to open map file /tmp/ms_tmp/bhdistritos.map in
> > > c:\arquivos
> > > > de programas\apache group\apache\htdocs\testes
> > on
> > > > line 7
> > > > Fatal error: Call to a member function on a non-object in
c:\arquivos
> de
> > > > programas\apache group\apache\htdocs\testes basicos\mapabasico.phtml
> on
> > > line
> > > > 8
> > > > i tried all type of paths in my map (and in my tab) files, and
> nothing.
> > > > cheers
> > > > Hugo Rodrigues
> > > > Analista/Consultor
> > > > SSSS - Prodabel
> > > > Sent: Tuesday, December 16, 2003 11:33 AM
> > > > > Hugo,
> > > > > I can' t make it work. That's why you are testing if you could.
> > > > > Could you please send me your tab file, the one that display a
white
> > > > screen
> > > > > so I can test it here I see what happen.
> > > > > Thanks,
> > > > > Denis
> > > > > Sent: Tuesday, December 16, 2003 2:28 PM
> > > > > > how you make it works? i mean, is the same thing of the last
file
> > you
> > > > send
> > > > > > me, and i still have this when i run:
> > > > > > Warning: [MapServer Error]: msDrawMap(): Failed to draw layer
> named
> > > > > 'test'.
> > > > > > in c:\arquivos de programas\apache
> > > > > > group\apache\htdocs\maisumexemploforum\mapabasico.phtml on line
8
> > > > > > Warning: [MapServer Error]: msOGRFileOpen(): Open failed for OGR
> > > > > connection
> > > > > > `./test.tab'. File not found or unsupported format. in
c:\arquivos
> > de
> > > > > > programas\apache
> > > > > on
> > > > > > line 8
> > c:\arquivos
> > > de
> > > > > > programas\apache
> > > > > on
> > > > > > line 9
> > > > > > (not the blank map, but the error messages).
> > > > > > Hugo Rodrigues
> > > > > > Analista/Consultor
> > > > > > SSSS - Prodabel
> > > > > > Sent: Tuesday, December 16, 2003 10:58 AM
> > > > > > > Hugo,
> > > > > > > Here is the file. Give it a go and let me know,
> > > > > > > Cheers,
> > > > > > > Denis
> > > > > > > To: "Chiang Zeliang" <chiang_8_3 at hotmail.com>
> > > > > > > Sent: Tuesday, December 16, 2003 1:49 PM
> > > > > > > > please, send the contents of your .map file, because im
trying
> > to
> > > > open
> > > > > > one
> > > > > > > > .tab file myself and maybe your map file works for me
> > > > > > > > cheers
> > > > > > > > Hugo Rodrigues
> > > > > > > > Analista/Consultor
> > > > > > > > SSSS - Prodabel
> > > > > > > > From: "Chiang Zeliang" <chiang_8_3 at hotmail.com>
> > > > > > > > To: <Mapserver-users at lists.gis.umn.edu>
> > > > > > > > Sent: Tuesday, December 16, 2003 2:50 AM
> > > > > > > > Subject: [Mapserver-users] Empty screen with .tab file?
> > > > > > > > > Hi all,
> > > > > > > > > I seem to have problems in opening a certain .tab file.
The
> > .tab
> > > > > file
> > > > > > is
> > > > > > > a
> > > > > > > > > map of roads with its name and reference. It shows an
empty
> > > screen
> > > > > > > > whenever
> > > > > > > > > I use mapserver to open it, is this suppose to happen?
Need
> > > help.
> > > > > > > Thanks.
> > > > > > > > > From,
> > > > > > > > > Zeliang
> > > _________________________________________________________________
> > > > > > > > > Are you in love? Find a date on MSN Personals
> > > > > http://match.msn.com.my/
> > > > > > > > > Mapserver-users mailing list
> > > > > > > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
