[Mapserver-users] time support
Steve Lime steve.lime at dnr.state.mn.us
Tue Dec 16 18:12:58 EST 2003
Do you mean TILEINDEX or the new TIMEINDEX? I could certainly see doing
filtering on the TIMEINDEX, especially as applied to non-raster data.
Using filters on tiles could certainly be done but would there be any
real practical use for the output. The new TIMEINDEX is accomanied by a
TIMEID, and the TIMEID could be interpreted as a MapServer expression so
you could process mutiple files at one time. That would be more work to
add than simply interpreting TIMEID as a single value.
I fear I'm missing your point...
Steve
>>> Daniel Morissette <morissette at dmsolutions.ca> 12/16/2003 4:44:40 PM
Steve Lime wrote:
> 2) As part of WCS support I'm adding the notion of a temporal index
to
> MapServer. The idea being that you would use a tabular index (an
xbase
> file) to organize data within a single layer temporally and then
would
> specify which slice to use using some sort of a temporal id. That
way
> you could serve 100's of images for a common geographic area using a
> single layer definition. There may well be benefits for vector data
as
> well.
Steve,
How about allowing FILTER/FILTERITEM to be applied to data fields in
the
TILEINDEX? You would end up combining the spatial and temporal index
into a single file. That would do the trick without any significant
change in MapServer.
Daniel
  Daniel Morissette               morissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
