[Mapserver-users] Empty screen with .tab file?
Denis Louvegnies
denis at louvegnies.com
Wed Dec 17 05:08:40 EST 2003
Hi Bo,
Thank you for your answer. Where did you get php_mapscript_40.dll from? I
can't find it. Maybe you can send it to me?
Could you please also send me your test files (the 4 mapInfo files and the
file.map file)
Many thanks,
Denis
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, December 17, 2003 10:39 AM
Subject: Re: [Mapserver-users] Empty screen with .tab file?
> Hi all -
> I'll think there is a bug in the php_mapscript_41.dll regarding the use of
> tab files. I've have an MapScript application using tab-files and defined
> with with full pathnames in the map-file. The environment is win2k and
using
> the ms4w ver. 0.7 setup. The application works perfectly when using the
> php_mapscript_40.dll. If I change the mapscript-dll from
> php_mapscript_40.dll to php_mapscript_41.dll I'll get the following error:
> Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
'Skove'.
> in C:\ms4w\apps\vvgis\html\vvgis.php on line 581
> Warning: [MapServer Error]: msOGRFileOpen(): Open failed for OGR
connection
> `c:\vvdata\testomr\gisdata\Skov.tab'. File not found or unsupported
format.
> Fatal error: Call to a member function on a non-object in
> C:\ms4w\apps\vvgis\html\vvgis.php on line 586
> regards
> Bo Thomsen
> GeoConsult I/S
> Denmark
> -----Oprindelig meddelelse-----
> Fra: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sendt: 16. december 2003 23:53
> Til: Denis Louvegnies
> Cc: Hugo Nathaniel Rodrigues; mapserver-users at lists.gis.umn.edu
> Emne: Re: [Mapserver-users] Empty screen with .tab file?
> Denis Louvegnies wrote:
> > Hi Daniel,
> > Hugo and I have the same problem.
> > For me even with the absolute path it still doesn't work.
> > I wounder if any one could open a MapInfo file with
> php_mapscript41.dll....
> Unfortunately I'm not setup to test on Windows so I can't help. Perhaps
> you can file a bug with all the details and your data file and if/when
> another developer on Windows has time to test this then they'll get back
> to you.
> BTW, did you try loading the same file with another DLL for version 4.0
> or 3.6?
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
