[Mapserver-users] Empty screen with .tab file?
Hugo Nathaniel Rodrigues
hugo at pbh.gov.br
Wed Dec 17 08:24:13 EST 2003
this i didnt tried, and the absolute path, i tried it all, with DOS path,
(c:\anything), with the "/" (/anything/anything), without path (all the
files in the same folder), etc etc etc...
nothing works
cheers
Hugo Rodrigues
Analista/Consultor
SSSS - Prodabel
----- Original Message -----
To: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
Sent: Tuesday, December 16, 2003 5:58 PM
Subject: Re: [Mapserver-users] Empty screen with .tab file?
> Hugo,
> I tried but didb't suceed. What about you? did you try?
> Thanks,
> Denis
> From: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
> To: "Denis Louvegnies" <denis at louvegnies.com>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Tuesday, December 16, 2003 6:02 PM
> > i found this, maybe help:
> > - Seamless layers will not work in "No Path" mode unless all layers are
in
> > the same folder as the Seamless layer. MapServer will return:
> > "msOGRFileOpen(): OGR error. Open failed for OGR connection
> > `\MyPath\MySeamlessLayer.TAB'. File not found or unsupported format. "
> > Using "Full Path" mode to create your seamless layer will also not work
> > unless the drive mapping on your MapServer machine matches that of the
> > machine you have MapInfo on for the layers. If you have a centralized
> > geographic data store like I do, your only option may be to place all
> layers
> > into the same folder and create your Seamless layer. MapInfo
> > cheers
> > Hugo Rodrigues
> > Analista/Consultor
> > SSSS - Prodabel
> > From: "Denis Louvegnies" <denis at louvegnies.com>
> > Sent: Tuesday, December 16, 2003 2:36 PM
> > > Hugo,
> > > I don't know if the problem is the version of that DLL. Let me know
your
> > > result if you are testing another version.
> > > Thanks,
> > > Denis
> > > Sent: Tuesday, December 16, 2003 5:17 PM
> > > > yes, im using that php_mapscript (file
> > > > php_mapscript_4.1-php-4.3.2-Oct72003.zip), maybe is this? maybe i
need
> > to
> > > > try other version? (wich this one i had too many problems with path
> > names,
> > > > but i solve it all using the complete DOS path).
> > > > cheers
> > > > Hugo Rodrigues
> > > > Analista/Consultor
> > > > SSSS - Prodabel
> > > > Sent: Tuesday, December 16, 2003 2:08 PM
> > > > > Hugo,
> > > > > I agree. We have the same conclusion. We have the same error...
Are
> > you
> > > > > using php_mapscript41.dll?
> > > > > The ogrinfo.exe comes from openev_fw package. you should be able
to
> > find
> > > > it
> > > > > in the mapserver download section.
> > > > > Sent: Tuesday, December 16, 2003 4:58 PM
> > > > > > i just tested one thing:
> > > > > > i commented the lines:
> > > > > > CONNECTIONTYPE OGR
> > > > > > CONNECTION "./distrito.tab"
> > > > > > and with that, i received a blank screen, now im sure (again)
that
> > the
> > > > > > problem in anything with the ogr connection.
> > > > > > Hugo Rodrigues
> > > > > > Analista/Consultor
> > > > > > SSSS - Prodabel
> > > > > > Sent: Tuesday, December 16, 2003 1:36 PM
> > > > > > > one END is missing at the end of your bhdistritos.map file
> > > > > > > Denis
> > > > > > > Sent: Tuesday, December 16, 2003 4:11 PM
> > > > > > > > here are my mapinfo files.
> > > > > > > > i receive all warnings and fatal errors, and cant open it :
> > > > > > > > Warning: [MapServer Error]: msLoadMap(): in c:\arquivos de
> > > > > > > programas\apache
> > > > > > > > group\apache\htdocs\testes basicos\mapabasico.phtml on line
7
> > > > > > > > Warning: Failed to open map file /tmp/ms_tmp/bhdistritos.map
> in
> > > > > > > c:\arquivos
> > > > > > > > de programas\apache group\apache\htdocs\testes
> > > > > > on
> > > > > > > > line 7
> > > > > > > > Fatal error: Call to a member function on a non-object in
> > > > c:\arquivos
> > > > > de
> > > > > on
> > > > > > > line
> > > > > > > > 8
> > > > > > > > i tried all type of paths in my map (and in my tab) files,
and
> > > > > nothing.
> > > > > > > > cheers
> > > > > > > > Hugo Rodrigues
> > > > > > > > Analista/Consultor
> > > > > > > > SSSS - Prodabel
> > > > > > > > Sent: Tuesday, December 16, 2003 11:33 AM
> > > > > > > > > Hugo,
> > > > > > > > > I can' t make it work. That's why you are testing if you
> > could.
> > > > > > > > > Could you please send me your tab file, the one that
display
> a
> > > > white
> > > > > > > > screen
> > > > > > > > > so I can test it here I see what happen.
> > > > > > > > > Thanks,
> > > > > > > > > Denis
> > > > > > > > > Sent: Tuesday, December 16, 2003 2:28 PM
file?
> > > > > > > > > > how you make it works? i mean, is the same thing of the
> last
> > > > file
> > > > > > you
> > > > > > > > send
> > > > > > > > > > me, and i still have this when i run:
> > > > > > > > > > Warning: [MapServer Error]: msDrawMap(): Failed to draw
> > layer
> > > > > named
> > > > > > > > > 'test'.
> > > > > > > > > > in c:\arquivos de programas\apache
> > > > > > > > > > group\apache\htdocs\maisumexemploforum\mapabasico.phtml
on
> > > line
> > > > 8
> > > > > > > > > > Warning: [MapServer Error]: msOGRFileOpen(): Open failed
> for
> > > OGR
> > > > > > > > > connection
> > > > > > > > > > `./test.tab'. File not found or unsupported format. in
> > > > c:\arquivos
> > > > > > de
> > > > > > > > > > programas\apache
> > > > > > > > > on
> > > > > > > > > > line 8
in
> > > > > > c:\arquivos
> > > > > > > de
> > > > > > > > > > programas\apache
> > > > > > > > > on
> > > > > > > > > > line 9
> > > > > > > > > > (not the blank map, but the error messages).
> > > > > > > > > > Hugo Rodrigues
> > > > > > > > > > Analista/Consultor
> > > > > > > > > > SSSS - Prodabel
> > > > > > > > > > Sent: Tuesday, December 16, 2003 10:58 AM
> file?
> > > > > > > > > > > Hugo,
> > > > > > > > > > > Here is the file. Give it a go and let me know,
> > > > > > > > > > > Cheers,
> > > > > > > > > > > Denis
> > > > > > > > > > > To: "Chiang Zeliang" <chiang_8_3 at hotmail.com>
> > > > > > > > > > > Sent: Tuesday, December 16, 2003 1:49 PM
> > file?
> > > > > > > > > > > > please, send the contents of your .map file, because
> im
> > > > trying
> > > > > > to
> > > > > > > > open
> > > > > > > > > > one
> > > > > > > > > > > > .tab file myself and maybe your map file works for
me
> > > > > > > > > > > > cheers
> > > > > > > > > > > > Hugo Rodrigues
> > > > > > > > > > > > Analista/Consultor
> > > > > > > > > > > > SSSS - Prodabel
> > > > > > > > > > > > From: "Chiang Zeliang" <chiang_8_3 at hotmail.com>
> > > > > > > > > > > > To: <Mapserver-users at lists.gis.umn.edu>
> > > > > > > > > > > > Sent: Tuesday, December 16, 2003 2:50 AM
> > > > > > > > > > > > Subject: [Mapserver-users] Empty screen with .tab
> file?
> > > > > > > > > > > > > Hi all,
> > > > > > > > > > > > > I seem to have problems in opening a certain .tab
> > file.
> > > > The
> > > > > > .tab
> > > > > > > > > file
> > > > > > > > > > is
> > > > > > > > > > > a
> > > > > > > > > > > > > map of roads with its name and reference. It shows
> an
> > > > empty
> > > > > > > screen
> > > > > > > > > > > > whenever
> > > > > > > > > > > > > I use mapserver to open it, is this suppose to
> happen?
> > > > Need
> > > > > > > help.
> > > > > > > > > > > Thanks.
> > > > > > > > > > > > > From,
> > > > > > > > > > > > > Zeliang
> _________________________________________________________________
> > > > > > > > > > > > > Are you in love? Find a date on MSN Personals
> > > > > > > > > http://match.msn.com.my/
> > > > > > > > > > > > > Mapserver-users mailing list
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
