[Mapserver-users] ms_newprojectionObj - change from v3.6
to v4.0??
Debbie Pagurek
pagurekd at agr.gc.ca
Wed Dec 17 14:57:56 EST 2003
This is a MIME message. If you are reading this text, you may want to
consider changing to a mail reader or gateway that understands how to
properly handle MIME multipart messages.
--=_5B058959.0362380F
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Paul, thanks for your help. I now see the difference in the v3.6 code
and v4.0.
The documentation for the ProjectionObj Class on this page is incorrect
however.
http://mapserver.gis.umn.edu/doc40/phpmapscript-class-guide.html#proj
$poPoint = $poPoint->project($projInObj, $projOutObj);
This is incorrect - it should be just
Perhaps someone could update that part of the documentation.
Thanks again for your help,
Debbie
>>> pagameba at magma.ca 12/16/03 10:34PM >>>
Debbie, from the php mapscript class reference, it looks like it returns
a result code instead of a new rectobj, and the projection is applied to
the actual rectobj rather than a copy. So your code should read:
$newproj=ms_newprojectionObj( "proj=robin,lon_0=0,x_0=0,y_0=0" );
$latlon = ms_newprojectionObj (
"proj=longlat,ellps=GRS80,datum=NAD83,no_defs" );
$oRect= ms_newRectObj();
$oRect->setextent( $bounds[0], $bounds[1],
$bounds[2], $bounds[3] );
$oRect->project( $latlon,$newproj); //the extent in
$map->setextent( $oRect->minx, $oRect->miny,
$oRect->maxx, $oRect->maxy );
Cheers,
Paul
Debbie Pagurek wrote:
> * *Hi all,
> I am trying to get some code that worked with php_mapscript_36.so to
> work with php_mapscript_40.so but am having problems.
> This worked before:
> $newproj=ms_newprojectionObj("proj=robin,lon_0=0,x_0=0,y_0=0");
> $latlon =
> ms_newprojectionObj("proj=longlat,ellps=GRS80,datum=NAD83,no_defs");
> $oldext= ms_newRectObj();
> $oldext->setextent($bounds[0],$bounds[1],$bounds[2],$bounds[3]);
> //the extent in latlong
> $newextproj = ms_newRectObj();
> $newextproj = $oldext->project($latlon,$newproj); //the extent in
> Robinson
$map->setextent($newextproj->minx,$newextproj->miny,$newextproj->maxx,$newextproj->maxy);
> But now when I try to see the new map extents e.g.
> echo "new ext minx = ".$newextproj->minx;
> I'm getting nothing.
> Has something else changed with Mapserver4 / php_mapscript_40.so?
> Can anyone give me any pointers?
> Thanks in advance.
> D. Pagurek
|Paul Spencer spencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
Content-Type: text/html; charset=ISO-8859-1
Content-Transfer-Encoding: 8bit
Content-Description: HTML
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="MSHTML 6.00.2800.1276" name=GENERATOR></HEAD>
<BODY style="MARGIN-TOP: 2px; FONT: 10pt Arial; MARGIN-LEFT: 2px">
<DIV>Paul, thanks for your help. I now see the difference in the v3.6 code
and v4.0.</DIV>
<DIV>The documentation for the ProjectionObj Class on this page is incorrect
however.</DIV>
<DIV><A
href="http://mapserver.gis.umn.edu/doc40/phpmapscript-class-guide.html#proj">http://mapserver.gis.umn.edu/doc40/phpmapscript-class-guide.html#proj</A></DIV>
<DIV>
<P> $poPoint = $poPoint->project($projInObj,
$projOutObj); <BR><BR>This is incorrect - it should be just </P>
<P>$poPoint->project($projInObj, $projOutObj); <BR><BR>Perhaps someone
could update that part of the documentation.</P>
<P>Thanks again for your help,<BR>Debbie</P>
<P><BR>>>> pagameba at magma.ca 12/16/03 10:34PM >>><BR>Debbie,
from the php mapscript class reference, it looks like it returns <BR>a result
code instead of a new rectobj, and the projection is applied to <BR>the actual
read:<BR><BR>$newproj=ms_newprojectionObj( "proj=robin,lon_0=0,x_0=0,y_0=0"
);<BR>$latlon = ms_newprojectionObj
(<BR>
"proj=longlat,ellps=GRS80,datum=NAD83,no_defs" );<BR><BR>$oRect=
ms_newRectObj();<BR>$oRect->setextent( $bounds[0],
$bounds[1],<BR>
$bounds[2], $bounds[3] );<BR>$oRect->project( $latlon,$newproj); //the
extent in<BR>$map->setextent( $oRect->minx,
$oRect->miny,<BR>
$oRect->maxx, $oRect->maxy );<BR><BR>Cheers,<BR><BR>Paul<BR><BR>Debbie
Pagurek wrote:<BR><BR>> * *Hi all,<BR>> I am trying to get some code
that worked with php_mapscript_36.so to <BR>> work with php_mapscript_40.so
but am having problems.<BR>> <BR>> This worked
before:<BR>>
$newproj=ms_newprojectionObj("proj=robin,lon_0=0,x_0=0,y_0=0");<BR>>
$latlon = <BR>>
ms_newprojectionObj("proj=longlat,ellps=GRS80,datum=NAD83,no_defs");<BR>>
<BR>> $oldext= ms_newRectObj();<BR>>
<BR>> //the extent in latlong<BR>> <BR>> $newextproj =
ms_newRectObj();<BR>> $newextproj =
$oldext->project($latlon,$newproj); //the extent in <BR>>
Robinson<BR>> <BR>> <BR>>
$map->setextent($newextproj->minx,$newextproj->miny,$newextproj->maxx,$newextproj->maxy);<BR>>
But now when I try to see the new map extents e.g.<BR>> echo "new ext minx =
".$newextproj->minx;<BR>> I'm getting nothing.<BR>> <BR>> Has
something else changed with Mapserver4 / php_mapscript_40.so?<BR>> Can anyone
give me any pointers?<BR>> <BR>> Thanks in advance.<BR>> D.
Pagurek<BR>> <BR><BR>-- <BR>
-----------------------------------------------------------------<BR>|Paul
Spencer
|<BR>|-----------------------------------------------------------------|<BR>|Applications
& Software
Development
|<BR>|DM Solutions Group
Inc
<A href="http://www.dmsolutions.ca/|">http://www.dmsolutions.ca/|</A><BR>
-----------------------------------------------------------------<BR><BR></P></DIV></BODY></HTML>
--=_5B058959.0362380F--
