R: [Mapserver-users] Mapinfo symbols
Ballini Yvain Ballini.Yvain at seat.it
Thu Dec 18 05:13:22 EST 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C3C54F.91374BFB
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Thanks for your answer, indeed it's a problem to manage the angle value =
for point symbol.
The other part of my question was about recognizing the symbol =
mapinfo-sym-111: ok, I cant' see the angle value of the point, but I'm =
also unable to see the registered symbols (mapinfo-sym-111 or the =
MapInfo "old style" mapinfo-sym-32), and I have to put the default =
symbol (a pixel) or one of mines. Doing so, I loss the information about =
orientation and that's a critical loss for arrows which should precisely =
indicate the street directions...! :)
For the testcase, I send you an extract of my tab file (small_arrow.tab, =
small_arrow.map, small_arrow.map, small_arrow.id) and also the same =
version converted in shapefile (small_arrow.shp, small_arrow.shp, =
small_arrow.dbf)  with the mapfile test_demo.map which should enable to =
see it (it's in a zone of Milan). Nel tab file di test the symbols which =
are used are mapinfo-sym-111 and mapinfo-sym-32. This layer "arrow" is =
the only one that I can't see correctly and completely in my =
application.
Thank you very much again!  :)
Yvain.
-----Messaggio originale-----
Da: Daniel Morissette [mailto:morissette at dmsolutions.ca]=20
Inviato: gioved=EC 18 dicembre 2003 0.43
A: Ballini Yvain
Cc: mapserver-users at lists.gis.umn.edu
Oggetto: Re: [Mapserver-users] Mapinfo symbols
Yvain,
Um, I checked the code and it seems that we ignore the angle value =
coming from STYLEITEM AUTO for point symbols. Could please you submit a =
bug with a small mapfile and arrow.tab to reproduce this? I'm not sure =
when we would have time to work on this, but with a testcase to =
reproduce it's always easier for us.
Thanks
Daniel
Ballini Yvain wrote:
> Hi list,
>=20
> I would like to read the arrows of a .tab file in mapserver: the pb is =
> that I can read the position but not the orientation of the arrow=20
> which is contained in the "Style" line of the .tab (see under).
> when I try to read my file arrow.tab with ogrinfo it turns me these=20
> properties for the arrow layer:
>=20
> Layer name: arrow
> Geometry: Point
> Feature Count: 267349
> Extent: (6.682870, 36.681040) - (18.495850, 46.895265) Layer SRS WKT:
> GEOGCS["unnamed",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563],
>         TOWGS84[0,0,0,0,0,0,0]],
>     PRIMEM["Greenwich",0],
>     UNIT["degree",0.0174532925199433]]
> LABEL: String (70.0)
> OGRFeature(arrow):1
>   LABEL (String) =3D
>   Style =3D =
SYMBOL(a:322,c:#4144ae,s:13pt,id:"mapinfo-sym-111.ogr-sym-1")
>   POINT (8.85458500 45.96559000)
>=20
> OGRFeature(arrow):2
>   LABEL (String) =3D
>   Style =3D =
>=20
> I define my arrow layer like that:
> LAYER
>   NAME freccie_navtech
>   PROJECTION
>   "proj=3Dlonglat"
>   "ellps=3Dintl"
>   "no_defs"
>   END
>   STATUS OFF
>   DATA arrow#chiave_in_piazzale_segesta#arrow#vie3_polyline
>   CONNECTIONTYPE OGR
>   CONNECTION
> "c:\mapserver\itasca\data\arrow.tab"#chiave_in_piazzale_segesta.tab"#a
> rr
> ow.tab"
>   STYLEITEM "AUTO"
>   TYPE point
>    CLASS
>     #STYLE
>     #  SYMBOL arrow
>     #  size 20
>       COLOR 88 88 245
>       #ANTIALIAS TRUE
>     #END
>   END
> END
>=20
> I think I can't recognize the id mapinfo-sym-111 which represents the=20
> arrow...but the position of the default point symbol is right on the=20
> map.
> Does someone know something about this problem or if there is a=20
> setting in the mapfile which could solve my problem?
> Thanks a lot.
> Yvain. =20
>=20
>=20
Content-Type: application/x-zip-compressed;
	name="small_arrow.zip"
Content-Transfer-Encoding: base64
Content-Description: small_arrow.zip
Content-Disposition: attachment;
	filename="small_arrow.zip"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Content-Type: application/octet-stream;
	name="test_demo.map"
Content-Description: test_demo.map
	filename="test_demo.map"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------_=_NextPart_001_01C3C54F.91374BFB--
