[Mapserver-users] Re: Thanks !!!
Hugo Nathaniel Rodrigues hugo at pbh.gov.br
Thu Dec 18 11:40:40 EST 2003
ok, lets answer all questions:
1) php_mapscript_41.dll -> cant make this one work, i think that the problem
is anything about the path, but cant make it work, im using
php_mapscript_35.dll too (looks like is the last stable version).
2) EXTENT values: with the ogrinfo.exe, you can get it from the openVe zip,
ftp://ftp.remotesensing.org/pub/gdal/openev/ (do not use the exe
installation, take one of the zip files), in the zip you will find the
ogrinfo.exe, put it in one pathed folder in your computer
(c:\windows\system32 if you have NT or XP), or put it with your mapinfo
files (same folder), then go to DOS prompt (start - programs - accessories -
MSDOS Prompt), and then, go to the folder you have your mapinfo files
(command CD in DOS), and type "ogrinfo -al yourfile.TAB", with that you will
have many information, and from the start of the information is the "EXTENT"
thing. (maybe you will have this message: "cant find anything.dll file", you
will find this dll in the same zip (openev), and you only need to copy it to
the system32 folder of your windows (or system if is win98, blah blah blah),
and then, try it again.
3) OUTLINECOLOR name.... i see it in gmap75.map file (with the gmap demo i
downloaded from dmsolutions http://www2.dmsolutions.ca/mapserver/dl/), and
that i has thinking about change the color to stop the blank screen, i tried
all the color locations in all the map file... (actually i tried COLOR
first, but then i geted one country with all gray into, then i tried the
outlinecolor), but you can have all this information from here:
http://mapserver.gis.umn.edu/doc40/mapfile-reference.html (this guide have
ALL about map files).
and... yep, im from brazil (cuzz that i have this so bad english, i never
studied english, maybe i learned from all my read from internet)
and dont thank me, thank Daniel Morissette, he is the guru, im only one
newbie user... one really happy newbie user  :)
cheers!!!
Hugo Rodrigues
Analista/Consultor
SSSS - Prodabel
----- Original Message -----
To: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
Sent: Thursday, December 18, 2003 2:13 PM
Subject: Thanks !!!
> Hugo,
> Thank you very much !!! it works !!! I am using php_mapscritp_35.dll.
> 1) Have you tryed with 41.dll.
> 2) How did you get the number EXTENT -1.178182 -0.352727 0.472727 0.570909
> From?
> 3) How did you know that OUTLINECOLOR name?
> Thanks you so much!!!
> by the way are you from Brasil ?
> Denis
> From: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
> To: "Denis Louvegnies" <denis at louvegnies.com>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Thursday, December 18, 2003 4:58 PM
> Subject: Re: [Mapserver-users] i found it!!!! i found it!!!!!!
> > denis
> > take a look in the messages from the forum, i just sended a message to
you
> > with this information and your files back.
> > cheers
> > Hugo Rodrigues
> > Analista/Consultor
> > SSSS - Prodabel
> > From: "Denis Louvegnies" <denis at louvegnies.com>
> > Sent: Thursday, December 18, 2003 1:45 PM
> > > Hello Hugo,
> > > I am just back from a two days meeting and according to your message
you
> > > have fix the pb for viewing mapInfo file.
> > > Could you please sumaries in a few points what to do to fix the
problem,
> I
> > > will be very gratefull !!
> > > Thank you very much,
> > > Denis
> > > To: "Daniel Morissette" <morissette at dmsolutions.ca>
> > > Sent: Thursday, December 18, 2003 4:24 PM
> > > > yes, i did that, and worked, im in the heaven now....
> > > > really thanks again Daniel!!!!
> > > > cheers
> > > > Hugo Rodrigues
> > > > Analista/Consultor
> > > > SSSS - Prodabel
> > > > From: "Daniel Morissette" <morissette at dmsolutions.ca>
> > > > Sent: Wednesday, December 17, 2003 9:45 PM
> > > > > Hugo Nathaniel Rodrigues wrote:
> > > > > > now, i only need to see this (i think my last question):
> > > > > > with ogrinfo i found this information:
> > > > > > INFO: Open of `distrito.tab'
> > > > > > using driver `MapInfo File' successful.
> > > > > > Layer name: distrito
> > > > > > Geometry: Polygon
> > > > > > Feature Count: 9
> > > > > > Extent: (598047.223047, 781652.733880) - (619791.428883,
> > > 812944.406142)
> > > > > > with that, i know my type (polygon), my connection (ogr), my
unit
> > > > > > (meters), but, i dont know what i need to put in "EXTENT", can
> > anyone
> > > > > > help me?
> > > > > The syntax of the EXTENT directive is:
> > > > >    EXTENT [minx] [miny] [maxx] [maxy]
> > > > > So based on the OGRINFO output above, you should use:
> > > > >    EXTENT 598047.223047 781652.733880 619791.428883 812944.406142
> > > > > Daniel
> > > > >   Daniel Morissette               morissette at dmsolutions.ca
> > > > >   DM Solutions Group              http://www.dmsolutions.ca/
> > > > _______________________________________________
> > > > Mapserver-users mailing list
> > > > Mapserver-users at lists.gis.umn.edu
> > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
