[Mapserver-users] Mapscript Java Compilation Problems
Satheesh Mani smani at izarinc.com
Thu Dec 18 12:31:06 EST 2003
Hello all,
Im getting the following compilation errors while doing the Java Compile
for
SWIG generated java files.(Using MapServer4.0.1, SWIG-1.3.20, Java
1.4.2)
./mapscript/outputFormatObj.java:134: setExtension(java.lang.String) is
already
defined in mapscript.outputFormatObj
  public void setExtension(String extension) {
./mapscript/outputFormatObj.java:138: setMimetype(java.lang.String) is
already defined in mapscript.outputFormatObj
  public void setMimetype(String mimetype) {
./mapscript/mapObj.java:299: clone() in mapscript.mapObj cannot override
clone() in java.lang.Object; attempting to use incompatible return type
found   : mapscript.mapObj
required: java.lang.Object
  public mapObj clone() {
3 errors
Please help.
Thanks
Satheesh
