[Mapserver-users] .tab files problems again
Chiang Zeliang chiang_8_3 at hotmail.com
Thu Dec 18 23:59:07 EST 2003
I have a similar problem and i have checked my .tab file with ogrinfo. Can
you help me and determine what type and coding should i use for this .tab
file?
thanks
From,
Zeliang
This is what i've got using ogrinfo:
Layer name: Msia_Mainroads
Geometry: Line String
Feature Count: 3662
Extent: (-85297.812205, 102267.713704) - (2090681.069111, 829390.210029)
Layer SRS WKT:
PROJCS["unnamed",
       GEOGCS["unnamed",
               DATUM["WGS_1984",
                       SPHEROID["WGS 84",6378137,298.257223563],
                       TOWGS84[0,0,0,0,0,0,0]],
               PRIMEM["Greenwich",0]
               UNIT["degree",0.0174532925199433]],
       PROJECTION["Transverse_Mercator"],
       PARAMETER["latitude_of_origin",0],
       PARAMETER["central_meridian",105],
       PARAMETER["scale_factor",0.9996],
       PARAMETER["false_easting",500000],
       PARAMETER["false_northing",0],
       UNIT["Meter",1.0]]
Rd_name: String (50.0)
Rd_No: String (50.0)
Type: String (50.0)
This is the coding i am using for this layer:
LAYER
  NAME 'Msia_Mainroads'
  TYPE line
  STATUS DEFAULT
  CONNECTIONTYPE OGR
  CONNECTION "C:\Inetpub\wwwroot\VesselTracking\Data\Msia_Mainroads.TAB"
  STYLEITEM "AUTO"
  MAXSCALE 5000000.0
  CLASS
  END
  PROJECTION
    "AUTO"
  END
END # Layer
>From: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
>To: "Riccardo Stuper" <rik_stpr at yahoo.it>
>CC: <mapserver-users at lists.gis.umn.edu>
>Subject: Re: [Mapserver-users] .tab files problems again
>Date: Thu, 18 Dec 2003 15:51:49 -0200
>Riccardo,
>i think i found your problem: you didnt create an alias, let me explain:
>to use the folder
>   IMAGEPATH "../ms_tmp"
>   IMAGEURL "/maplab-2.1-RC1/ms_tmp"
>in the WEB section of your MAP file, you need to have it in your httpd.conf
>of your apache configuration, like this:
>     Alias /gmap/   "C:/Arquivos de programas/Apache
>Group/Apache/htdocs/gmap/"
>     Alias /ms_tmp/ "C:/tmp/ms_tmp/"
>and you need to have this folders... in my case, i tried your map file, and
>get one little box with red X (like one no found jpg in the page), then, i
>tried the same map file using my configuration of WEB section:
>   IMAGEPATH "/tmp/ms_tmp/"
>   IMAGEURL "/ms_tmp/"
>and then worked well (now i have that blue map), the other thing that you
>need its a php file like the one im sending to you (now, if you can do it
>without php file, i dont know, because i just started).
>cheers
>Hugo Rodrigues
>Analista/Consultor
>SSSS - Prodabel
>   ----- Original Message -----
>   From: Riccardo Stuper
>   To: Hugo Nathaniel Rodrigues
>   Sent: Thursday, December 18, 2003 2:54 PM
>   Hugo,
>   here are my files. There is only one layer, very simple. I add one of
>the html file I've tried to use, just in case there would be something
>horribly wrong in it...
>   Thank you very much for your help.
>   cheers
>   RS
>   Hugo Nathaniel Rodrigues <hugo at pbh.gov.br> wrote:
>     send me your files (mapserver .map and all the mapinfo files) i will
>see if i can run here.
>     cheers
>     Hugo Rodrigues
>     Analista/Consultor
>     SSSS - Prodabel
>       Cc: mapserver-users at lists.gis.umn.edu
>       Sent: Thursday, December 18, 2003 8:26 AM
>       Hugo,
>       thanx for answer. I've tried ogrinfo, it tells "Open of
>`Friuli.tab'... successful" then all the informations. (I notice I need to
>put the "ogrinfo.exe" in the same folder of the files to analyze).
>       I put the extent in my map file, nothing. White map, no ref, no
>scale as always. Neither imagecolor helps.
>       Maybe it's something else w/ogr connection (but ogrinfo tells it's
>ok), some dll missing, Apache configuration, I followed the instructions
>and all seems ok, the demo was working.
>       I cannot understand why I could open the map w/MapLap-MapEdit tool
>and no way else, but I cannot use always this...
>       I don't know what to do. Thx anyway.
>       cheers
>       R.S.
>         riccardo,
>         first of all, go to DOS prompt and type ogrinfo friuli.tab (if you
>dont have the ogrinfo file, download it in
>ftp://ftp.remotesensing.org/pub/gdal/openev/ (you need to download any FW
>or linux version, but not the win32 exe version, because the installation
>dont have the ogrinfo file), then unzip it and take the ogrinfo file (when
>you run the ogrinfo file, this will show you some dll files that is not in
>your windows dll folder, you will found it in the zip file, and can put it
>in windows/system32, or system, depends of the version of your windows, but
>take care to not copy this if you have other version installed).
>         with the ogrinfo working, and the information you get (ogrinfo -al
>-ro friuli.tab), get the information of EXTENDED and put it in your map
>file (take of the one you have).
>         maybe this works, if not, try to put imagecolor in your map file
>start section (imagecolor 255 255 255).
>         i wish this can help you.
>         cheers
>         Hugo Rodrigues
>         Analista/Consultor
>         SSSS - Prodabel
>       Yahoo! Mail: 6MB di spazio gratuito, 30MB per i tuoi allegati,
>l'antivirus, il filtro Anti-spam
><< mapabasico.zip >>
_________________________________________________________________
Using a handphone prepaid card? Reload your credit online!
http://www.msn.com.my/reloadredir/default.asp
