[Mapserver-users] about shapefile
Aga Shirazi ashirazi at buffalo.edu
Tue Dec 23 11:32:03 EST 2003
I'm interested in learning about the raw shapefile and how I could write my
owm program to read it. Its just for knowledge sake so I'm really not
interested in the programs that are already out there.
I would be greatly appreciative if someone could guide me some resources.
Thanks
Aga Shirazi
--On Tuesday, December 23, 2003 11:15:50 AM -0500 Lowell Filak
<lfilak at medinaco.org> wrote:
> It's seems like there are several tools out there which already allow
> for the direct manipulation of shapefiles at a more generic level than
> delving into the actual shapefile structure.
> Are you sure that your needs could not be met by one of the existing
> applications/libraries, ie. MapScript?
> Lowell
> The following message was sent by Aga Shirazi <ashirazi at buffalo.edu> on
> Tue, 23 Dec 2003 10:54:00 -0500.
>> Hi,
>> I wanted to learn how a shpefile is structured, created and compiled. I
>> read the technical description from ESRI about Shapefiles, but I couldnt
>> get much out of it as I lack a GIS programming background. For
> instance: I
>> have no idea what PolygonZ or M is, and why would I use it. I also
> couldnt
>> find in the Tech. paper how can I code and compile a shapefile?
>> I would be greatly appreciative if someone could name some websites or
>> books that could guide me.
>> Thanks
>> Aga Shirazi
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
