[Mapserver-users] MS 4.0 CGI Bug ?
David Fawcett David.Fawcett at state.mn.us
Tue Dec 23 16:00:47 EST 2003
Steve,
Look at TEMPLATEPATTERN in the LAYER object.
http://mapserver.gis.umn.edu/doc40/mapfile-reference.html#templatepattern
To swap templates through URL substitution, you have to set an
expression in template pattern that will match the name of your
template.
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> <woodbri at swoodbridge.com> 12/23/2003 2:42:11 PM >>>
Unless, I am doing something wrong (which is highly likely :), I can
not get the CGI interface to replace the TEMPLATE value in the
mapfile.
I have tried using:
http://....&template=%2Fhome%2Fmsapps%2Ftest_mapfiles%2Ftest_40z_main.
html&....
and
http://....&map_web_template=%2Fhome%2Fmsapps%2Ftest_mapfiles%2Ftest_4
0z_main.html&....
but neither will replace the template defined in the mapfile.
Can anyone verify this works or doesn't work on mapserver 4.0? so I
can write a bug if appropriate.
Thanks,
  Steve W.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
