[Mapserver-users] Raw shapefile question
Steve Lime steve.lime at dnr.state.mn.us
Fri Dec 26 13:38:30 EST 2003
A shapefile is just a format for storing data as described in the
document below. There is no language, compiler or anything else. You can
write a shapefile reader/writer in any language you choose, but this has
already been done... There are lot's of shapefile examples you can
download off the web.
Steve
>>> Aga Shirazi <ashirazi at buffalo.edu> 12/23/2003 11:39:12 AM >>>
I was goin through the Technical Description for Shapefiles from ESRI
at
www.esri.com/library/whitepapers/pdfs/shapefile.pdf
I like to know in which languge is the file being coded.
Are the tables (the record and content tables of Shape Type) used just
in
designing? Or some compiler actually utalizes this data.
Does anyone have a source code of any shapefile along with its final
shapefile. I just need an example to understand.
I really appreciate all the replies.
Thanks a million
Aga Shirazi
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
