[Mapserver-users] Join in 4.0 displays field name, not values, from DBF
Steve Lime steve.lime at dnr.state.mn.us
Mon Dec 29 10:26:32 EST 2003
Can you share the dbf, shape and map files?
Steve
>>> Chris Storozuk <cstorozuk at shaw.ca> 12/28/2003 11:29:47 AM >>>
Using a one-to-many join, I am unable to retrieve any data from my
linked
DBF file. The query is basically ignoring any fields I place in my
JOIN
template, which is, simply:
<li> [SHEET_NAME]: [DATA]<br>,
where DATA is a valid field name. The query results in a bunch of
records,
but also a bunch of [DATA] strings, not the values for the DATA field.
As
well, I have determined that the link is working, because I see as
many
records returned as there are records in the DBF.
If I add a bogus field name (eg. DATA2), it simply displays [DATA2]
instead
of [DATA], which leads me to believe that it is not even trying to get
the
data from the DBF.
I am generating the DBFs using Excel, saving as DBF 4 (and I have tried
3 as
well).
Thanks,
Chris Storozuk
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
