[Mapserver-users] help with python mapscript (no image)
Sean Gillies
sgillies at frii.com
Tue Dec 30 13:58:48 EST 2003
Cristoph,
Glad to help. There are more tips about using Python MapScript at
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PythonMapScript
I'm using mod_python as well. Maybe you'd be interested in
sharing notes about it on the Wiki site?
The advantage to using a string's join method is that it makes for
more readable and maintainable code. Another good alternative is
this type of statement
filename = '%s.%s' % (myMap.name, myImg.format.extension)
cheers,
Sean
On Tuesday, December 30, 2003, at 11:38 AM, Christoph Spoerri wrote:
> Hi Sean,
> thanks for your help. The code and comments you sent were very
> usefull. I had
> to changed the code a bit to make it work, but I saw that you had to
> save the
> map image explicit to a file (w/ name) set the URL appropriately. With
> the
> PHP mapscript this is done for you.
> Thanks for your help!
> Christoph
> BTW. is there an advantage to using join() than using '+' to append
> strings?
> On Tuesday 30 December 2003 12:38 pm, Sean Gillies wrote:
>> Hi Cristoph,
>> Are you using 4.0.1? If not, I strongly recommend that you download
>> and build MapServer 4.0.1.
>> I'll try to explain the right way to do this with a little script:
>> # I'm pretty sure that import * is safe, but not 100% sure
>> from mapscript import mapObj
>> import os
>> # Create map instance
>> myMap = mapObj('/var/www/htdocs/mapserver/obis_test/testing.map')
>> # Draw map. The resulting image acquires 'imagepath' and
>> # 'imageurl' attributes from myMap and also acquires a 'format'
>> # that is the same as the selected format of myMap, in this
>> # case the built-in 'PNG24' format as defined in your map file
>> mapImg = myMap.draw()
>> # Save image to the imageurl location using a filename formed
>> # from the map name and the output format extension, result
>> # in your case will be 'PYDEMO.png'
>> imagename = '.'.join((myMap.name, mapImg.format.extension))
>> mapImg.save(os.path.join(mapImg.imageurl, imagename))
>> The IMAGEURL is a directory name. It's not really required for a
>> Python MapScript app like it is with the mapserv CGI, but it remains
>> useful.
>> Hope this helps, cheers,
>> Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
