[Mapserver-users] RE: problem with boundaries
ryanne cruz
ryanne.cruz at up.edu.ph
Tue Feb 4 00:08:11 EST 2003
This message is in MIME format.
---MOQ1044335291cdca3f8a638c1be57172226440afb27b
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: 8bit
hi list.
i have included in this email a sample of the map that we were able to
display. as you can see, the data is not contained within the map. some are
in
the fringes. i used the distance function to get these data. an example is:
select the_geom from table1 where
distance(table1.the_geom,table2.the_geom)=0;
this was the closest thing i could get, in terms of the map bounding the
data.
any ideas on how i could make it better?
thanks!
Content-Type: image/png; name="sample.png"
Content-Transfer-Encoding: base64
Content-Disposition: attachment; filename="sample.png"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-Type: image/png; name="original.png"
Content-Disposition: attachment; filename="original.png"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==
---MOQ1044335291cdca3f8a638c1be57172226440afb27b--
