[Mapserver-users] 3.6.4 compilation troubles in Solaris
Daniel Morissette morissette at dmsolutions.ca
Tue Feb 4 12:09:28 EST 2003
Doug Nebert wrote:
> I have successfully found GD and PROJ resources to use with mapserver
> on the Sun under Solaris but am getting the following error in a
> default make. I need only to get the mapserv executable that supports
> WMS.  Any suggestions on how to fix what's missing?
> lm   -o shp2img
> Undefined                       first referenced
>  symbol                             in file
> gdImageCopyMerge                    ./libmap.a(maputil.o)
I believe gdImageCopyMerge() was added only around GD 1.6, for sure GD
1.2, 1.3 and 1.4 didn't have it.  Sounds like you'll have to replace
your GD with a more recent version, any version between GD 1.6 and 1.8.4
should do.
 DM Solutions Group              http://www.dmsolutions.ca/
