[Mapserver-users] Projection woes, Revisited.
David Blasby dblasby at refractions.net
Tue Feb 4 13:50:51 EST 2003
Ed McNierney wrote:
> The PROJ4 FAQ refers to the work you need to do to have the NAD datum shift files built - the code doesn't change.
This isnt quite true.  You might have to modify  "pj_datums.c".  Just make sure all your datum shift files are mentioned.  Proj doesnt, by default, use all of them!
dave
