[Mapserver-users] Zoom error with Python
Sven Jacobi jacobi at dfki.de
Wed Feb 5 08:43:23 EST 2003
Hello,
I'm using Mapserver inside Zope and I'm writing External methods
(Python Scripts) to call the C-libraries.
I receive errors when I try to zoom in a map, but when using the same code
for zooming out or panning, it works?!
Below there's the small part of code responsible for that. I have no idea
where this might come from...
Any help?
Thanks,
Sven
The error is as follows:
  File "/home/jacobi/Funkland/Zope-2.5.1b2-src/Extensions/mapserv.py", line
79, in ?
    drawmap(['1','5'], '3', '1', '200', '200')
45, in drawmap
    myimage=mymap.draw()
  File "/home/jacobi/Funkland/site-packages/MapScript.py", line 1941, in draw
    val = MapScriptc.mapObj_draw(self.this)
RuntimeError: msSearchDiskTree(): Unable to access file.
Exception exceptions.RuntimeError: 'msSearchDiskTree(): Unable to access file.
\n' in <method mapObjPtr.__del__ of mapObj instance at f155c> ignored</italic>
def drawmap(layer, zoomfactor, zoomdirection, imgx, imgy):
 mymap = mapObj("/home/jacobi/public_html/Funkland/brenschel2.map")
 mymap.prepareImage()
 mymap.width=600
 mymap.height=400
#----- Zooming und Panning
 zoomfac = int(zoomfactor)
 zoomdir = int(zoomdirection)
 xi = int(imgx)
 yi = int(imgy)
 #Zoomfaktor auslesen
 if (zoomdir == 0):
  zoom = 1
  print 'zoom0'
 elif (zoomdir == -1):
  zoom = 1.0/zoomfac
  print 'zoom-1'
 elif (zoomdir == 1):
  zoom = zoomfac
  print 'zoom1'
  print zoom
 #Berechnung der "Zellengroesse"
 cx = (mymap.extent.maxx - mymap.extent.minx)/mymap.width
 cy = (mymap.extent.maxy - mymap.extent.miny)/mymap.height
 #Berechnung der Mapkoordinaten aus den Imagekoordinaten
 x = mymap.extent.minx + cx * xi
 y = mymap.extent.maxy - cy * yi
 #Berechnung des neuen Extends
 mymap.extent.minx = x - 0.5 * ((mymap.extent.maxx-mymap.extent.minx) / zoom)
 mymap.extent.miny = y - 0.5 * ((mymap.extent.maxy-mymap.extent.miny) / zoom)
 mymap.extent.maxx = x + 0.5 * ((mymap.extent.maxx-mymap.extent.minx) / zoom)
 mymap.extent.maxy = y + 0.5 * ((mymap.extent.maxy-mymap.extent.miny) / zoom)
 #print mymap.extent.minx
#----- END Zooming und Panning
#----- Layeroptionen
 if (len(layer)!=1):
	for i in range (0,len(layer)):
                #print i
		if (layer[i]=='1'):
			layer0 = mymap.getLayer(0)
			layer0.status = 1
 			layer0.draw(mymap, myimage)
		elif (layer[i]=='2'):
			layer1 = mymap.getLayer(1)
			layer1.status = 1
 			layer1.draw(mymap, myimage)
		elif (layer[i]=='3'):
			layer2 = mymap.getLayer(2)
			layer2.status = 1
 			layer2.draw(mymap, myimage)
		elif (layer[i]=='4'):
			layer3 = mymap.getLayer(3)
			layer3.status = 1
 			layer3.draw(mymap, myimage)
		elif (layer[i]=='5'):
			layer4 = mymap.getLayer(4)
			layer4.status = 1
 			layer4.draw(mymap, myimage)
#----- END Layeroptionen
 #myimage=mymap.draw()
 mymap.drawLabelCache(myimage)
 out = myimage.saveImage("brenschel.png",MS_PNG,50,0,50)
 return out
drawmap(['1','5'], '3', '1', '200', '200')</smaller>
