[Mapserver-users] Map Extent
Lowell Filak
lfilak at medinaco.org
Thu Feb 6 10:13:52 EST 2003
I think because your x extents are negative you need to change '$x = $imgext[0] + $cx*$x;' to '$x = $imgext[0] - $cx*$x;' or '$x = $imgext[0] + abs($cx*$x);'.
The original code was developed for Minnesota & stateplane so a negative was not required.
HTH
Lowell F.
The following message was sent by Eric Bridger <eric at gomoos.org> on 03 Feb 2003 13:45:39 +0000.
> Hi all. I am a new mapserver, mapscript user, about 2 weeks now. So
> first my thanks to all involved in developing a truly excellent
> application. We are using Mapserver 3.6.4 and mapscript to develop an
> Linux Apache/mod-perl oceanographic application.
> I am having trouble mapping the users map image mouse click to map
> coordinates with precision. At first I thought it might be the
> registration of the map datasets we were using (shape files) with one
> shaded relief jpg, so I switched to using the states_ugl data and the
> s1ex1.map from the 3.6 tutorial in a simple mapscript test and noticed
> the same issues.
> When adding a point symbol to the map at the location clicked, the
> symbol appears near where I expected but not exactly where I expected.
> The closer I click to the center of the map the closer the symbol
> registers. It appears to me that the y-coordinate is always on target,
> but that the x corrdinate is off. The closer to the edges of the map,
> the further off the x coordinate is.
> Perhaps this has to do with the fact that the map created 400x300 goes
> all the way from y=0 to y=400, but not from x=0 to x=300?
> The mapextent is gotten from the map object created from the map file.
> I calculate the map coordinates with code adapted from the mapquakes.pl
> example:
> if($q->param('img.x') && $q->param('imgext')) { # Make sure we got a
> click
> @imgext = split(' ', $q->param('imgext'));
> $x = $q->param('img.x');
> $y = $q->param('img.y');
> $cx = ($imgext[2]-$imgext[0])/($map->{width}-1);
> $cy = ($imgext[3]-$imgext[1])/($map->{height}-1);
> $y = $imgext[3] - $cy*$y;
> Create a point object and add it to the map and display it.
> Par of the map file:
> MAP
> EXTENT -97.238976 41.619778 -82.122902 49.38562
> SIZE 400 300
> SHAPEPATH "/home/eric/work/htdocs/mapserver/tutorial35/data"
> # Added by EB
> IMAGETYPE PNG
> UNITS DD
> LAYER # States
> NAME "lobster_zones"
> DATA states_ugl
> STATUS DEFAULT
> TYPE POLYGON
> CLASSITEM "STATE"
> CLASS
> NAME "Michigan"
> COLOR 255 255 128
> OUTLINECOLOR 0 0 0
> END # end of class object
> END # end of layer object
> Thanks.
> Eric Bridger
> eric at gomoos.org
> Gulf of Maine Ocean Observing System www.gomoos.org
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
