[Mapserver-users] more mapplet questions
Martin, Daniel DMartin at erac.com
Thu Feb 6 14:56:59 EST 2003
There is a version of Rosa that supports PNG.  And I use it, so I know it
works.  You download the standard Rosa package,
http://www2.dmsolutions.ca/webtools/rosa/rosa_downloads.html, but instead of
using rosa.jar you use rosa_png.jar.  But perhaps you don't want Rosa.
I don't know if there is a released version of mapplet that supports PNG.  I
recall someone was working on adding sixlegs to mapplet, but I'm not sure
what came of it.  Search the archives for mapplet png and you'll find
postings about it.
-Dan Martin
> -----Original Message-----
> From: Kevin Slover [mailto:Kevin.Slover at noaa.gov]
> Sent: Thursday, February 06, 2003 1:30 PM
> To: Mapserver Mailing-List
> Subject: [Mapserver-users] more mapplet questions
> Thanks for all the help so far.  I am sorry for continuing
> posting these
> trivial questions.. hopefully once I get a base for how this
> is exactly
> working, they will lessen...
> I have finally gotten mapplet to run.  However, I am running into the
> issue of the "gray box".  Being that all images are png, is this the
> problem?  I have read that the mapplet does not work with png's, but
> also remember reading that newer versions of java are able to display
> png's... is this correct?  I am using java2 platform, version
> 1.4.1 on a
> WIN XP to view the page, but everything is being scripted on a RedHat
> 7.2 server... the error is giving me:
> document.mapserv.imgbox is null or not an object.
> LTJG Kevin Slover, NOAA
> GIS Specialist/Oceanographer
> NOAA/TPC/TSB/Storm Surge Unit
> 11691 SW 17th Street
> Miami FL  33165
> W (305) 229-4456
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
