[Mapserver-users] Large Map Files
Lowther, David W dlowther at ou.edu
Tue Feb 11 14:05:55 EST 2003
ABSOLUTELY. That would be so very useful.
Dave
> -----Original Message-----
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: Tuesday, February 11, 2003 1:03 PM
> To: Jan Hartmann
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Large Map Files
> I have been thinking that an extremely powerful extension to the .map
> file would be an "INCLUDE" directive, which reads a map file fragment
> into another map file.  A quick-and-dirty map service could then be
> assembled with:
> MAP
>    INCLUDE standard-headers.map
>    INCLUDE standard-basemap-layers.map
>    LAYER
>      NAME myspeciallayer
>      DATA blah
>      TYPE polygon
>    END
> END
> The FME does this in its mapping files, for example. The
> first stage of
> processing is to replace all INCLUDE lines with their referenced
> content. It recursively does this up to a max number of loops.
> For people maintaining alot of different map services, it could be a
> real boon. (Your parcel postgis database is now on a new
> server? Change
> the *one* parcel layer definition, and all the maps which
> reference it
> are now up-to-date.)
> P.
> Jan Hartmann wrote:
> > Just my personal view, but isn't this problem of too many
> classes (or
> > layers) perhaps caused by using a MapFile in two different
> ways: as a
> > generator of a single layered map, and as a repository of
> all available
> > map layers? I can hardly imagine a single map with more than fifty
> > classes or one hundred layers. What people seem to do is
> putting every
> > GIS file they have in a single MapFile and turning layers
> on and off as
> > needed. As every layer needs its own classes, the maximum
> number of 50
> > is very soon reached, even if only a small part of these
> will be ever
> > used in any actual map.
>        __
>       | Paul Ramsey
>       | Refractions Research
>       | Email: pramsey at refractions.net
>       | Phone: (250) 885-0632
>       \_
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
