[Mapserver-users] Checkbox with java help
christian.schuster at rsag.ch
Thu Feb 13 08:44:27 EST 2003
Make sure that you also have the tag ["layer name"_checked] included in the
html input tag.
Change your input tag as following
<input type="checkbox" name="layer" value="florida_roads1" align="left"
[florida_roads1_checked] onClick="Refresh();" > Roads 1<br>
Christian Schuster
Rudolf Schuster AG
Postfach 277
CH - 3000 Bern 11
http://www.rsag.ch
++41 31 348 05 30
"Kevin Slover"
<Kevin.Slover at noa
a.gov> To
Sent by: Mapserver Mailing-List
mapserver-users-a <mapserver-users at lists.gis.umn.edu>
dmin at lists.gis.um cc
n.edu
Subject
13.02.2003 14:36 java help
Hello all!!
Looking for a little bit of help right now. The small problem is as
follows:
I am using a checkbox to select which layer is to be displayed.
Following a few of the examples out there, I have been able to get the
display to refresh on click. However, the checkbox becomes unchecked.
And I am only able to display one layer at a time... I am not sure where
the problem resides, I have looked at several other sites, and they have
the same code... mine is as follows:
function Refresh(){
document.mapserv.target = "";
document.mapserv.mode.value = "browse";
document.mapserv.submit();
<form name="mapserv" method=GET action="[program]">
etc.. etc... etc..
I am using jBox, with version 3.6.4 on a RH 7.2. Any ideas!
Thanks! Cheers!
LTJG Kevin Slover, NOAA
GIS Specialist/Oceanographer
NOAA/TPC/TSB/Storm Surge Unit
11691 SW 17th Street
Miami FL 33165
W (305) 229-4456
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
