[Mapserver-users] did something change between 3.6.3 and 3.6.4?
Caffeinate The World
mochaexpress at yahoo.com
Sun Feb 16 14:05:41 EST 2003
--- Daniel Morissette <morissette at dmsolutions.ca> wrote:
> If you do a 'view source' in the output of this page then you'll
> notice
> that the HTML is truncated. This is likely an indication of a crash.
> You could first look at your Apache error_log to look for hints.
Nothing in the error_log at all.
> There is nothing that changed between 3.6.3 and 3.6.4 to justify that
> crash. So I suspect that your 3.6.4 build has some problem. Make
> sure
> you don't have an old /usr/local/lib/libmap.a ... if you do then
> delete
> it and redo your build.
Everything was clean. But just to make sure, I removed all traces of
the old 3.6.3 install and rebuilt 3.6.4. Same problem.
I have the other tutorials (example1 and example2) working. Just when I
got to the gmap demo it truncates the output. I suspect if there were
problems with the mapscript php module 3.6.4 in general, it would fail
on example1 and example2 as well. It didn't. Which leads me to believe
that maybe gmap uses some function of mapscript that the other 2
examples don't use.
Example1 demo:
http://www.minnesota.com/~tom/mapserver/demo/php/examples/tutorial/example1.phpc
Example2 demo:
http://www.minnesota.com/~tom/mapserver/demo/php/examples/tutorial/example2.phpc
__________________________________________________
Do you Yahoo!?
Yahoo! Shopping - Send Flowers for Valentine's Day
http://shopping.yahoo.com
