[Mapserver-users] did something change between 3.6.3 and 3.6.4?
Caffeinate The World
mochaexpress at yahoo.com
Sun Feb 16 16:10:36 EST 2003
--- woodbri at swoodbridge.com wrote:
> Looks like just following the sources lines that get output from
> gmap75.phtml is the line:
> <TD WIDTH=<?php echo $gpoMap->width; ?>><?php
> GMapDumpQueryResults(); ?></TD>
> Try commenting out each of these in turn and see if you can get past
> this.
I ran with the cgi script from shell. It did crash where you said. I
tried to remove most of the mapscript related stuff AFTER that line
above and it didn't help.
In CLI mode from shell I was able to see that it core dumped. Ran gdb
on it and got this:
Reading symbols from /usr/X11R6/lib/libX11.so.6...done.
Loaded symbols for /usr/X11R6/lib/libX11.so.6
#0 0x16071f698 in drawTIFF ()
---Type <return> to continue, or q <return> to quit---
from
/usr/local_install/php-4.3/lib/php/extensions/no-debug-non-zts-20020429/php_mapscript.so
It's hanging on the drawTIFF function.
__________________________________________________
Do you Yahoo!?
Yahoo! Shopping - Send Flowers for Valentine's Day
http://shopping.yahoo.com
