[Mapserver-users] did something change between 3.6.3 and 3.6.4?
Daniel Morissette morissette at dmsolutions.ca
Mon Feb 17 13:32:20 EST 2003
There was no branching between 3.6.3 and 3.6.4, so anything that was in
3.6.3 must have been in 3.6.4.  But are you sure that Frank made any
change in 3.6.x for the TIFF problem you are referring to?  I didn't see
the conclusions of the thread that you are pointing to (did Frank end up
fixing something at the end?), but perhaps using --without-tiff in your
configure options would force using the GDAL TIFF driver and resolve the
issue?
Daniel
Caffeinate The World wrote:
> I found the answer. The compiled module I was using that DID work was
> from Nov 2002 CVS in which Frank Warmerdam help correct a bug in
> DrawTIFF() routine.
> Here is that thread.
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0211/msg00482.html
> I had thought that was 3.6.3. It wasn't.
> Recently I just compiled 3.6.4 and forgetting about the previous work
> Frank did and encountered the same problem with drawTIFF().
> Was Frank's work committed to CVS? Maybe 3.6.4 branched off before Nov
> 2002?
