[Mapserver-users] More MapScript 3.7 problems
fx gamoy
fx.gamoy at mapxplore.com
Tue Feb 18 06:52:40 EST 2003
hi,
tanks for your help
i he tried to make mapserver cooperate with the output format but apache
logs return me:
'call to undefined function : selectoutputformat()'
i am running a self compiled Mapscript3.7-dev release 1.115
The ouput format defined in my map file is
IMAGETYPE jpeg
OUTPUTFORMAT
NAME jpeg
MIMETYPE "image/jpeg"
DRIVER "GD/JPEG"
IMAGEMODE RGB
FORMATOPTION "QUALITY=80"
TRANSPARENT OFF
END
In the php file i have written
$map->selectOutputFormat("jpeg");
$map->draw();
any suggestion???
thanks a lot
fx gamoy
----- Original Message -----
To: "fx gamoy" <fx.gamoy at mapxplore.com>
Sent: Monday, February 17, 2003 9:13 PM
Subject: Re: [Mapserver-users] More MapScript 3.7 problems
> Hi fx (?),
> Yes I did. The problem was in the fact that 3.7 uses new entries i the MAP
file, namely IMAGETYPE and OUTPUTFORMAT.blocks. If
> they're included, you can use (e.g.) $map->selectOutputFormat("jpeg"); to
switch to JPEG output.
> The entries in the MAP file looks something like:
> IMAGETYPE jpeg
> OUTPUTFORMAT
> NAME jpeg
> DRIVER "GD/JPEG"
> IMAGEMODE RGB
> TRANSPARENT OFF
> END
> You need to check out the 3.7 Migration Guide.
> And please note that 3.7 may not support GIF anymore, depending on what
version of GD you've used. GD 2.0 certainly doesn't.
> Best regards/Med venlig hilsen
> Lars V. Nielsen
> GisPro, Denmark
> http://www.gispro.dk/
> http://hjem.get2net.dk/lars-online/
> WGS84: 10.20'40"E 55.20'20"N
> From: "fx gamoy" <fx.gamoy at mapxplore.com>
> To: "Lars V. Nielsen" <LVN at gispro.dk>
> Sent: Monday, February 17, 2003 10:48 PM
> > hi
> > i have compiled mapscript MapScript 3.7 (dev) ($Revision: 1.115) on my
linux
> > plateform and i ve got the same output problems than you..
> > did you find any solution?
> > thanks
> > fx gamoy
> > From: "Lars V. Nielsen" <LVN at gispro.dk>
> > To: "MAPSERVER-L" <mapserver-users at lists.gis.umn.edu>
> > Sent: Sunday, February 09, 2003 9:05 AM
> > Subject: [Mapserver-users] More MapScript 3.7 problems
> > > Hi,
> > > It seems that recently released MapScript 3.7 (dev) ($Revision: 1.143
> > $Date: 2003/02/04 15:39:43 $) only outputs interlaced GIF
> > > images regardless of using different settings in "saveImage" and
> > "saveWebImage". I've tried outputting PNG and JPEG, and tried to
> > > turn off interlacing, but nothing changes in the output.
> > > I'm running Win2000.
> > > Lars V. Nielsen
> > > GisPro, Denmark
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
