[Mapserver-users] New User - Compile problems...
Aaron Racicot aaronr at ccalmr.ogi.edu
Tue Feb 18 15:29:16 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_003C_01C2D749.5AC3A1B0
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: 8bit
Hello,
            I am a new user and am having problems getting mapserver to
compile for the first time.  I am compiling on a linux box and have gotten
the same error when trying mapserver version 3.5 and 3.6.4.  Can anyone out
there give me some clues as to what this might be?  I have included the
output from the configure and the make below…
Thanks
Aaron Racicot
Oregon Health Science University
OGI – School of science and engineering
CONFIGURE:
creating cache ./config.cache
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for c++... c++
checking whether the C++ compiler (c++  ) works... yes
checking whether the C++ compiler (c++  ) is a cross-compiler... no
checking whether we are using GNU C++... yes
checking whether c++ accepts -g... yes
checking for ranlib... ranlib
checking for flex... flex
checking for yywrap in -lfl... yes
checking for bison... bison -y
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking for exp in -lm... yes
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for strcasecmp... yes
checking for strncasecmp... yes
checking for strdup... yes
checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes
        using libjpeg from system libs.
checking which version of GD to use...
        using libgd from system libs.
checking where FreeType is installed...
checking for FT_Init_FreeType in -lfreetype... yes
        using libfreetype -lfreetype from system libs.
checking where Zlib is installed...
checking for zlibVersion in -lz... yes
        using libz from system libs.
checking where PNG is installed...
checking for png_init_io in -lpng... yes
        using libpng from system libs.
checking for gdImageCreate in -lgd... yes
checking for gdImageGif in -lgd... no
checking for gdImagePng in -lgd... yes
checking for gdImageJpeg in -lgd... yes
checking for gdImageWBMP in -lgd... yes
checking for gdImageStringFT in -lgd... yes
checking for gdImageString16 in -lgd... yes
checking for gdImageGifPtr in -lgd... no
        using GD ( -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT)
from system libs.
checking whether we should include PDF support...
checking for PDF_setlinewidth in -lpdf... no
checking for PDF_setrgbcolor in -lpdf... no
checking for PDF_moveto in -lpdf... no
checking for PDF_curveto in -lpdf... no
checking for PDF_show_xy in -lpdf... no
        libpdf not found... PDF support not included.
checking whether we should include TIFF support...
checking for TIFFOpen in -ltiff... yes
        using libtiff from system libs.
checking whether we should include EPPL7 support...
        including EPPL7 support.
checking whether we should include PROJ.4 support...
        PROJ.4 support not requested.
checking whether we should include ESRI SDE support...
        ESRI SDE support not requested.
checking whether we should compile in MPATROL support...
        MPATROL support not requested.
checking whether we should include OGR support...
        OGR support not requested.
checking if GDAL support requested... no
checking if PostGIS support requested... no
checking if OracleSpatial support requested... no
checking whether we should include WMS support...
        OGC WMS Compatibility not enabled (PROJ.4 is required for WMS).
checking whether we should include WMS Client Connections support...
        OGC WMS Client Connections not enabled (PROJ.4 and libwww required).
Compiling with -DIGNORE_MISSING_DATA.
checking for PHP/MapScript module options...
        PHP/MapScript module not configured.
updating cache ./config.cache
creating ./config.status
creating Makefile
MAKE (error):
gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -D
USE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include
shp2img.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltif
f -ljpeg -lfreetype -lpng -lz  -ljpeg          -lm   -o shp2img
./libmap.a(mapogr.o)(.eh_frame+0x11): undefined reference to
`__gxx_personality_v0'
collect2: ld returned 1 exit status
make: *** [shp2img] Error 1
MAKE (full output):
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG
 -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT       -I/usr/include
mapbits.c -o mapbits.o
cc1: warning: changing search order for system directory "/usr/include"
cc1: warning:   as it has already been specified as a non-system directory
maphash.c -o maphash.o
mapshape.c -o mapshape.o
mapxbase.c -o mapxbase.o
mapparser.c -o mapparser.o
maplexer.c -o maplexer.o
maplexer.c:3125: warning: `yyunput' defined but not used
maptree.c -o maptree.o
mapsearch.c -o mapsearch.o
mapstring.c -o mapstring.o
mapsymbol.c -o mapsymbol.o
mapfile.c -o mapfile.o
maplegend.c -o maplegend.o
maputil.c -o maputil.o
mapscale.c -o mapscale.o
mapquery.c -o mapquery.o
maplabel.c -o maplabel.o
maperror.c -o maperror.o
mapprimitive.c -o mapprimitive.o
mapprimitive.c:771: warning: `get_centroid' defined but not used
mapproject.c -o mapproject.o
mapraster.c -o mapraster.o
mapsde.c -o mapsde.o
c++ -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG
mapogr.cpp -o mapogr.o
cc1plus: warning: changing search order for system directory "/usr/include"
cc1plus: warning:   as it has already been specified as a non-system
directory
mappostgis.c -o mappostgis.o
maplayer.c -o maplayer.o
mapresample.c -o mapresample.o
mapresample.c:419: warning: `msInitApproxTransformer' defined but not used
mapresample.c:436: warning: `msFreeApproxTransformer' defined but not used
mapresample.c:447: warning: `msApproxTransformer' defined but not used
mapresample.c:551: warning: `msTransformMapToSource' defined but not used
mapwms.c -o mapwms.o
mapwmslayer.c -o mapwmslayer.o
maporaclespatial.c -o maporaclespatial.o
mapgml.c -o mapgml.o
mapgml.c: In function `gmlWriteBounds':
mapgml.c:73: warning: control reaches end of non-void function
mapprojhack.c -o mapprojhack.o
mapprojhack.c:71: warning: `ConvertProjUnitStringToMS' defined but not used
epplib.c -o epplib.o
ar rc libmap.a mapbits.o maphash.o mapshape.o mapxbase.o mapparser.o
maplexer.o maptree.o mapsearch.o mapstring.o mapsymbol.o mapfile.o
maplegend.o maputil.o mapscale.o mapquery.o maplabel.o maperror.o
mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o mappostgis.o
maplayer.o mapresample.o mapwms.o mapwmslayer.o maporaclespatial.o mapgml.o
mapprojhack.o epplib.o
ranlib libmap.a
shp2img.c -o shp2img.o
Content-Type: text/html;
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 9">
<meta name=3DOriginator content=3D"Microsoft Word 9">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C2D749.59902AC0">
<!--[if gte mso 9]><xml>
 <o:OfficeDocumentSettings>
  <o:DoNotRelyOnCSS/>
 </o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
 <w:WordDocument>
  <w:View>Normal</w:View>
  <w:Zoom>0</w:Zoom>
  <w:DocumentKind>DocumentEmail</w:DocumentKind>
  <w:EnvelopeVis/>
 </w:WordDocument>
</xml><![endif]-->
<style>
 /* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-parent:"";
	margin:0in;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:12.0pt;
	font-family:"Times New Roman";
	mso-fareast-font-family:"Times New Roman";}
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
	{margin:0in;
	font-size:12.0pt;
span.EmailStyle15
	{mso-style-type:personal-compose;
	mso-ansi-font-size:10.0pt;
	mso-ascii-font-family:Arial;
	mso-hansi-font-family:Arial;
	mso-bidi-font-family:Arial;
	color:black;}
@page Section1
	{size:8.5in 11.0in;
	margin:1.0in 1.25in 1.0in 1.25in;
	mso-header-margin:.5in;
	mso-footer-margin:.5in;
	mso-paper-source:0;}
div.Section1
	{page:Section1;}
</style>
</head>
<body lang=3DEN-US style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><span class=3DEmailStyle15><font size=3D2 =
color=3Dblack
face=3DArial><span =
style=3D'font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:
Arial'>Hello,<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span =
style=3D'mso-tab-count:1'>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp=
;&nbsp;&nbsp;&nbsp; </span>I
am a new user and am having problems getting mapserver to compile for =
the first
time.<span style=3D"mso-spacerun: yes">&nbsp; </span>I am compiling on a =
linux
box and have gotten the same error when trying mapserver version 3.5 and
3.6.4.<span style=3D"mso-spacerun: yes">&nbsp; </span>Can anyone out =
there give
me some clues as to what this might be?<span style=3D"mso-spacerun: =
yes">&nbsp;
</span>I have included the output from the configure and the make =
below&#8230; <o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><![if =
!supportEmptyParas]>&nbsp;<![endif]><o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>Thanks<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><![if =
color=3Dblack
Arial'>Aaron Racicot<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>Oregon Health Science =
University<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>OGI &#8211; School of science and =
engineering<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><![if =
<p class=3DMsoNormal><span class=3DEmailStyle15><b><font size=3D2 =
color=3Dblack
Arial;font-weight:bold'>CONFIGURE:<o:p></o:p></span></font></b></span></p=
<p class=3DMsoNormal =
style=3D'mso-layout-grid-align:none;text-autospace:none'><font
size=3D2 color=3Dblack face=3D"Courier New"><span =
style=3D'font-size:10.0pt;font-family:
"Courier New";color:black'>creating cache =
./config.cache</span></font><font
"Courier =
New";color:black;mso-color-alt:windowtext'><o:p></o:p></span></font></p>
"Courier New";color:black'>checking for gcc... gcc</span></font><font =
size=3D2
style=3D'font-size:10.0pt;font-family:"Courier New";
"Courier New";color:black'>checking whether the C compiler (gcc<span
style=3D"mso-spacerun: yes">&nbsp; </span>) works... =
yes</span></font><font
"Courier =
style=3D"mso-spacerun: yes">&nbsp; </span>) is a cross-compiler... =
no</span></font><font
"Courier =
"Courier New";color:black'>checking whether we are using GNU C... =
"Courier =
"Courier New";color:black'>checking whether gcc accepts -g... =
"Courier =
"Courier New";color:black'>checking for c++... c++</span></font><font =
size=3D2
"Courier New";color:black'>checking whether the C++ compiler (c++<span
"Courier =
"Courier =
"Courier New";color:black'>checking whether we are using GNU C++... =
"Courier =
"Courier New";color:black'>checking whether c++ accepts -g... =
"Courier =
"Courier New";color:black'>checking for ranlib... =
ranlib</span></font><font
"Courier =
"Courier New";color:black'>checking for flex... flex</span></font><font =
size=3D2
"Courier New";color:black'>checking for yywrap in -lfl... =
"Courier =
"Courier New";color:black'>checking for bison... bison =
-y</span></font><font
"Courier =
"Courier New";color:black'>checking if compiler supports -R... =
"Courier =
"Courier New";color:black'>checking if compiler supports -Wl,-rpath,... =
"Courier =
"Courier New";color:black'>checking for exp in -lm... =
"Courier =
"Courier New";color:black'>checking how to run the C preprocessor... gcc =
-E</span></font><font
"Courier =
"Courier New";color:black'>checking for ANSI C header files... =
"Courier =
"Courier New";color:black'>checking for strcasecmp... =
"Courier =
"Courier New";color:black'>checking for strncasecmp... =
"Courier =
"Courier New";color:black'>checking for strdup... yes</span></font><font
"Courier =
"Courier New";color:black'>checking whether we should include JPEG =
support...</span></font><font
"Courier =
"Courier New";color:black'>checking for jpeg_read_header in -ljpeg... =
"Courier =
"Courier New";color:black'><span style=3D"mso-spacerun:
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>using libjpeg =
from
system libs.</span></font><font size=3D2 color=3Dblack face=3D"Courier =
New"><span
style=3D'font-size:10.0pt;font-family:"Courier =
"Courier New";color:black'>checking which version of GD to =
use...</span></font><font
"Courier =
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>using libgd from =
system
New"><span
"Courier New";color:black'>checking where FreeType is =
installed...</span></font><font
"Courier =
"Courier New";color:black'>checking for FT_Init_FreeType in =
-lfreetype... yes</span></font><font
"Courier =
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>using libfreetype =
-lfreetype
from system libs.</span></font><font size=3D2 color=3Dblack =
"Courier New";color:black'>checking where Zlib is =
"Courier =
"Courier New";color:black'>checking for zlibVersion in -lz... =
"Courier =
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>using libz from =
system
New"><span
"Courier New";color:black'>checking where PNG is =
"Courier =
"Courier New";color:black'>checking for png_init_io in -lpng... =
"Courier =
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>using libpng from =
system
New"><span
"Courier New";color:black'>checking for gdImageCreate in -lgd... =
"Courier =
"Courier New";color:black'>checking for gdImageGif in -lgd... =
"Courier =
"Courier New";color:black'>checking for gdImagePng in -lgd... =
"Courier =
"Courier New";color:black'>checking for gdImageJpeg in -lgd... =
"Courier =
"Courier New";color:black'>checking for gdImageWBMP in -lgd... =
"Courier =
"Courier New";color:black'>checking for gdImageStringFT in -lgd... =
"Courier =
"Courier New";color:black'>checking for gdImageString16 in -lgd... =
"Courier =
"Courier New";color:black'>checking for gdImageGifPtr in -lgd... =
"Courier =
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>using GD ( =
-DUSE_GD_PNG
-DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT) from system =
"Courier =
"Courier New";color:black'>checking whether we should include PDF =
"Courier =
"Courier New";color:black'>checking for PDF_setlinewidth in -lpdf... =
"Courier =
"Courier New";color:black'>checking for PDF_setrgbcolor in -lpdf... =
"Courier =
"Courier New";color:black'>checking for PDF_moveto in -lpdf... =
"Courier =
"Courier New";color:black'>checking for PDF_curveto in -lpdf... =
"Courier =
"Courier New";color:black'>checking for PDF_show_xy in -lpdf... =
"Courier =
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>libpdf not =
found... PDF
support not included.</span></font><font size=3D2 color=3Dblack =
"Courier New";color:black'>checking whether we should include TIFF =
"Courier =
"Courier New";color:black'>checking for TIFFOpen in -ltiff... =
"Courier =
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>using libtiff =
from
New"><span
"Courier New";color:black'>checking whether we should include EPPL7 =
"Courier =
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>including EPPL7 =
support.</span></font><font
"Courier =
"Courier New";color:black'>checking whether we should include PROJ.4 =
"Courier =
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>PROJ.4 support =
not
requested.</span></font><font size=3D2 color=3Dblack face=3D"Courier =
New"><span
"Courier New";color:black'>checking whether we should include ESRI SDE
support...</span></font><font size=3D2 color=3Dblack face=3D"Courier =
New"><span
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>ESRI SDE support =
not
New"><span
"Courier New";color:black'>checking whether we should compile in MPATROL
New"><span
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>MPATROL support =
not
New"><span
"Courier New";color:black'>checking whether we should include OGR =
"Courier =
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>OGR support not
New"><span
"Courier New";color:black'>checking if GDAL support requested... =
"Courier =
"Courier New";color:black'>checking if PostGIS support requested... =
"Courier =
"Courier New";color:black'>checking if OracleSpatial support =
requested... no</span></font><font
"Courier =
"Courier New";color:black'>checking whether we should include WMS =
"Courier =
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>OGC WMS =
Compatibility
not enabled (PROJ.4 is required for WMS).</span></font><font size=3D2
"Courier New";color:black'>checking whether we should include WMS Client
Connections support...</span></font><font size=3D2 color=3Dblack =
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>OGC WMS Client
Connections not enabled (PROJ.4 and libwww required).</span></font><font
"Courier =
"Courier New";color:black'>Compiling with =
-DIGNORE_MISSING_DATA.</span></font><font
"Courier =
"Courier New";color:black'>checking for PHP/MapScript module =
options...</span></font><font
"Courier =
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>PHP/MapScript =
module not
configured.</span></font><font size=3D2 color=3Dblack face=3D"Courier =
New"><span
"Courier New";color:black'>updating cache =
"Courier =
"Courier New";color:black'>creating ./config.status</span></font><font =
size=3D2
"Courier New";color:black'>creating Makefile</span></font><font size=3D2
"Courier New";color:black'><![if =
!supportEmptyParas]>&nbsp;<![endif]></span></font><font
"Courier =
color=3Dblack
Arial'><![if =
color=3Dblack
Arial'><![if =
color=3Dblack
Arial;font-weight:bold'>MAKE =
(error):<o:p></o:p></span></font></b></span></p>
"Courier New";color:black'>gcc -O2<span style=3D"mso-spacerun: =
yes">&nbsp;
</span>-Wall -DIGNORE_MISSING_DATA<span style=3D"mso-spacerun: =
yes">&nbsp;
</span>-DUSE_EPPL <span style=3D"mso-spacerun:
yes">&nbsp;&nbsp;&nbsp;</span>-DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG =
-DUSE_GD_JPEG
-DUSE_GD_WBMP -DUSE_GD_FT<span style=3D"mso-spacerun:
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; =
</span>-I/usr/include<span
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n=
bsp;&nbsp;
</span>shp2img.o<span style=3D"mso-spacerun: yes">&nbsp; </span>-L. =
-lmap -lgd
-L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz<span style=3D"mso-spacerun:
yes">&nbsp; </span>-ltiff -ljpeg -lfreetype -lpng -lz<span =
yes">&nbsp; </span>-ljpeg<span style=3D"mso-spacerun:
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; =
</span>-lm<span
style=3D"mso-spacerun: yes">&nbsp;&nbsp; </span>-o =
shp2img</span></font><font
"Courier =
"Courier New";color:black'>./libmap.a(mapogr.o)(.eh_frame+0x11): =
undefined
reference to `__gxx_personality_v0'</span></font><font size=3D2 =
color=3Dblack
"Courier New";color:black'>collect2: ld returned 1 exit =
"Courier =
"Courier New";color:black'>make: *** [shp2img] Error =
1</span></font><font
"Courier =
"Courier =
"Courier =
"Courier =
color=3Dblack
Arial;font-weight:bold'>MAKE (full =
output):<o:p></o:p></span></font></b></span></p>
"Courier New";color:black'>gcc -c -O2<span style=3D"mso-spacerun: =
yes">&nbsp;
yes">&nbsp;
</span>-DUSE_EPPL<span style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp;
</span>-DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_FT<span style=3D"mso-spacerun: =
</span>-I/usr/include<span style=3D"mso-spacerun:
bsp;&nbsp;
</span>mapbits.c -o mapbits.o</span></font><font size=3D2 color=3Dblack
"Courier New";color:black'>cc1: warning: changing search order for =
system
directory &quot;/usr/include&quot;</span></font><font size=3D2 =
color=3Dblack
"Courier New";color:black'>cc1: warning:<span style=3D"mso-spacerun:
yes">&nbsp;&nbsp; </span>as it has already been specified as a =
non-system
directory</span></font><font size=3D2 color=3Dblack face=3D"Courier =
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>maphash.c -o maphash.o</span></font><font size=3D2 color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapshape.c -o mapshape.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapxbase.c -o mapxbase.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapparser.c -o mapparser.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>maplexer.c -o maplexer.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
"Courier New";color:black'>maplexer.c:3125: warning: `yyunput' defined =
but not
used</span></font><font size=3D2 color=3Dblack face=3D"Courier =
New"><span
yes">&nbsp;
yes">&nbsp;
-DUSE_GD_FT<span style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp; =
</span><span
style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp;</span>-I/usr/include<span
bsp;&nbsp;
</span>maptree.c -o maptree.o</span></font><font size=3D2 color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
</span>-DUSE_EPPL<span style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp; =
</span>-DUSE_TIFF
-DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT<span
style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
bsp;&nbsp;
</span>mapsearch.c -o mapsearch.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapstring.c -o mapstring.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapsymbol.c -o mapsymbol.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapfile.c -o mapfile.o</span></font><font size=3D2 color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>maplegend.c -o maplegend.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>maputil.c -o maputil.o</span></font><font size=3D2 color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapscale.c -o mapscale.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapquery.c -o mapquery.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
</span>-DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP =
-DUSE_GD_FT<span
bsp;&nbsp;
</span>maplabel.c -o maplabel.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>maperror.c -o maperror.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapprimitive.c -o mapprimitive.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
"Courier New";color:black'>mapprimitive.c:771: warning: `get_centroid' =
defined
but not used</span></font><font size=3D2 color=3Dblack face=3D"Courier =
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapproject.c -o mapproject.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapraster.c -o mapraster.o</span></font><font size=3D2 =
color=3Dblack
system directory
&quot;/usr/include&quot;</span></font><font size=3D2 color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span><span
style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;</span>mapsde.c -o =
mapsde.o</span></font><font
"Courier =
system
color=3Dblack
non-system
New"><span
"Courier New";color:black'>c++ -c -O2<span style=3D"mso-spacerun: =
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapogr.cpp -o mapogr.o</span></font><font size=3D2 color=3Dblack
"Courier New";color:black'>cc1plus: warning: changing search order for =
system
color=3Dblack
"Courier New";color:black'>cc1plus: warning:<span style=3D"mso-spacerun:
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mappostgis.c -o mappostgis.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>maplayer.c -o maplayer.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
-DUSE_GD_FT<span
bsp;&nbsp;
</span>mapresample.c -o mapresample.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
"Courier New";color:black'>mapresample.c:419: warning:
`msInitApproxTransformer' defined but not used</span></font><font =
size=3D2
"Courier New";color:black'>mapresample.c:436: warning:
`msFreeApproxTransformer' defined but not used</span></font><font =
size=3D2
"Courier New";color:black'>mapresample.c:447: warning: =
defined but not used</span></font><font size=3D2 color=3Dblack =
"Courier New";color:black'>mapresample.c:551: warning: =
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapwms.c -o mapwms.o</span></font><font size=3D2 color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapwmslayer.c -o mapwmslayer.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>maporaclespatial.c -o maporaclespatial.o</span></font><font =
size=3D2
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
</span><span style=3D"mso-spacerun: =
yes">&nbsp;</span>-I/usr/include<span
bsp;&nbsp;
</span>mapgml.c -o mapgml.o</span></font><font size=3D2 color=3Dblack
system
color=3Dblack
non-system
New"><span
"Courier New";color:black'>mapgml.c: In function =
`gmlWriteBounds':</span></font><font
"Courier =
"Courier New";color:black'>mapgml.c:73: warning: control reaches end of
non-void function</span></font><font size=3D2 color=3Dblack =
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>mapprojhack.c -o mapprojhack.o</span></font><font size=3D2 =
color=3Dblack
system
color=3Dblack
non-system
New"><span
"Courier New";color:black'>mapprojhack.c:71: warning:
`ConvertProjUnitStringToMS' defined but not used</span></font><font =
size=3D2
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>epplib.c -o epplib.o</span></font><font size=3D2 color=3Dblack
system
color=3Dblack
non-system
New"><span
"Courier New";color:black'>ar rc libmap.a mapbits.o maphash.o mapshape.o
mapxbase.o mapparser.o maplexer.o maptree.o mapsearch.o mapstring.o =
mapsymbol.o
mapfile.o maplegend.o maputil.o mapscale.o mapquery.o maplabel.o =
maperror.o
maplayer.o mapresample.o mapwms.o mapwmslayer.o maporaclespatial.o =
mapgml.o
mapprojhack.o epplib.o<span style=3D"mso-spacerun: yes">&nbsp; =
</span></span></font><font
"Courier =
"Courier New";color:black'>ranlib libmap.a</span></font><font size=3D2
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
</span>shp2img.c -o shp2img.o</span></font><font size=3D2 color=3Dblack
system
color=3Dblack
non-system
New"><span
yes">&nbsp;
yes">&nbsp;
bsp;&nbsp;
-lmap -lgd
yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>-lm<span
"Courier =
undefined
color=3Dblack
"Courier =
"Courier =
"Courier =
color=3Dblack
Arial'><![if =
color=3Dblack
Arial'><![if =
</div>
</body>
</html>
------=_NextPart_000_003C_01C2D749.5AC3A1B0--
