[Mapserver-users] New User - Compile problems...
Madere, Colin colin.madere at ieminc.com
Tue Feb 18 15:50:06 EST 2003
I had this problem on Solaris 8 too, and I _think_ this was the problem I
fixed by doing the following:
1) run configure with whatever options
2) edit "Makefile" and add " -lstdc++" to the end of the variable being set
named "STATIC_LIBS"
3) make
I've already posted this a couple of times, but it was quite recent so the
archives may not have picked it up...
> -----Original Message-----
> From:	Aaron Racicot [SMTP:aaronr at ccalmr.ogi.edu]
> Sent:	Tuesday, February 18, 2003 2:29 PM
> To:	mapserver-users at lists.gis.umn.edu
> Subject:	[Mapserver-users] New User - Compile problems...
> Hello,
>             I am a new user and am having problems getting mapserver to
> compile for the first time.  I am compiling on a linux box and have gotten
> the same error when trying mapserver version 3.5 and 3.6.4.  Can anyone
> out there give me some clues as to what this might be?  I have included
> the output from the configure and the make below...
> Thanks
> Aaron Racicot
> Oregon Health Science University
> OGI - School of science and engineering
> CONFIGURE:
> creating cache ./config.cache
> checking for gcc... gcc
> checking whether the C compiler (gcc  ) works... yes
> checking whether the C compiler (gcc  ) is a cross-compiler... no
> checking whether we are using GNU C... yes
> checking whether gcc accepts -g... yes
> checking for c++... c++
> checking whether the C++ compiler (c++  ) works... yes
> checking whether the C++ compiler (c++  ) is a cross-compiler... no
> checking whether we are using GNU C++... yes
> checking whether c++ accepts -g... yes
> checking for ranlib... ranlib
> checking for flex... flex
> checking for yywrap in -lfl... yes
> checking for bison... bison -y
> checking if compiler supports -R... no
> checking if compiler supports -Wl,-rpath,... yes
> checking for exp in -lm... yes
> checking how to run the C preprocessor... gcc -E
> checking for ANSI C header files... yes
> checking for strcasecmp... yes
> checking for strncasecmp... yes
> checking for strdup... yes
> checking whether we should include JPEG support...
> checking for jpeg_read_header in -ljpeg... yes
>         using libjpeg from system libs.
> checking which version of GD to use...
>         using libgd from system libs.
> checking where FreeType is installed...
> checking for FT_Init_FreeType in -lfreetype... yes
>         using libfreetype -lfreetype from system libs.
> checking where Zlib is installed...
> checking for zlibVersion in -lz... yes
>         using libz from system libs.
> checking where PNG is installed...
> checking for png_init_io in -lpng... yes
>         using libpng from system libs.
> checking for gdImageCreate in -lgd... yes
> checking for gdImageGif in -lgd... no
> checking for gdImagePng in -lgd... yes
> checking for gdImageJpeg in -lgd... yes
> checking for gdImageWBMP in -lgd... yes
> checking for gdImageStringFT in -lgd... yes
> checking for gdImageString16 in -lgd... yes
> checking for gdImageGifPtr in -lgd... no
>         using GD ( -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT)
> from system libs.
> checking whether we should include PDF support...
> checking for PDF_setlinewidth in -lpdf... no
> checking for PDF_setrgbcolor in -lpdf... no
> checking for PDF_moveto in -lpdf... no
> checking for PDF_curveto in -lpdf... no
> checking for PDF_show_xy in -lpdf... no
>         libpdf not found... PDF support not included.
> checking whether we should include TIFF support...
> checking for TIFFOpen in -ltiff... yes
>         using libtiff from system libs.
> checking whether we should include EPPL7 support...
>         including EPPL7 support.
> checking whether we should include PROJ.4 support...
>         PROJ.4 support not requested.
> checking whether we should include ESRI SDE support...
>         ESRI SDE support not requested.
> checking whether we should compile in MPATROL support...
>         MPATROL support not requested.
> checking whether we should include OGR support...
>         OGR support not requested.
> checking if GDAL support requested... no
> checking if PostGIS support requested... no
> checking if OracleSpatial support requested... no
> checking whether we should include WMS support...
>         OGC WMS Compatibility not enabled (PROJ.4 is required for WMS).
> checking whether we should include WMS Client Connections support...
>         OGC WMS Client Connections not enabled (PROJ.4 and libwww
> required).
> Compiling with -DIGNORE_MISSING_DATA.
> checking for PHP/MapScript module options...
>         PHP/MapScript module not configured.
> updating cache ./config.cache
> creating ./config.status
> creating Makefile
> MAKE (error):
> gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG
> -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include
> shp2img.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz
> -ltiff -ljpeg -lfreetype -lpng -lz  -ljpeg          -lm   -o shp2img
> ./libmap.a(mapogr.o)(.eh_frame+0x11): undefined reference to
> `__gxx_personality_v0'
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
> MAKE (full output):
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF
> -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> -I/usr/include              mapbits.c -o mapbits.o
> cc1: warning: changing search order for system directory "/usr/include"
> cc1: warning:   as it has already been specified as a non-system directory
> -I/usr/include              maphash.c -o maphash.o
> -I/usr/include              mapshape.c -o mapshape.o
> -I/usr/include              mapxbase.c -o mapxbase.o
> -I/usr/include              mapparser.c -o mapparser.o
> -I/usr/include              maplexer.c -o maplexer.o
> maplexer.c:3125: warning: `yyunput' defined but not used
> -I/usr/include              maptree.c -o maptree.o
> -I/usr/include              mapsearch.c -o mapsearch.o
> -I/usr/include              mapstring.c -o mapstring.o
> -I/usr/include              mapsymbol.c -o mapsymbol.o
> -I/usr/include              mapfile.c -o mapfile.o
> -I/usr/include              maplegend.c -o maplegend.o
> -I/usr/include              maputil.c -o maputil.o
> -I/usr/include              mapscale.c -o mapscale.o
> -I/usr/include              mapquery.c -o mapquery.o
> -I/usr/include              maplabel.c -o maplabel.o
> -I/usr/include              maperror.c -o maperror.o
> -I/usr/include              mapprimitive.c -o mapprimitive.o
> mapprimitive.c:771: warning: `get_centroid' defined but not used
> -I/usr/include              mapproject.c -o mapproject.o
> -I/usr/include              mapraster.c -o mapraster.o
> -I/usr/include              mapsde.c -o mapsde.o
> c++ -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF
> -I/usr/include              mapogr.cpp -o mapogr.o
> cc1plus: warning: changing search order for system directory
> "/usr/include"
> cc1plus: warning:   as it has already been specified as a non-system
> directory
> -I/usr/include              mappostgis.c -o mappostgis.o
> -I/usr/include              maplayer.c -o maplayer.o
> -I/usr/include              mapresample.c -o mapresample.o
> mapresample.c:419: warning: `msInitApproxTransformer' defined but not used
> mapresample.c:436: warning: `msFreeApproxTransformer' defined but not used
> mapresample.c:447: warning: `msApproxTransformer' defined but not used
> mapresample.c:551: warning: `msTransformMapToSource' defined but not used
> -I/usr/include              mapwms.c -o mapwms.o
> -I/usr/include              mapwmslayer.c -o mapwmslayer.o
> -I/usr/include              maporaclespatial.c -o maporaclespatial.o
> -I/usr/include              mapgml.c -o mapgml.o
> mapgml.c: In function `gmlWriteBounds':
> mapgml.c:73: warning: control reaches end of non-void function
> -I/usr/include              mapprojhack.c -o mapprojhack.o
> mapprojhack.c:71: warning: `ConvertProjUnitStringToMS' defined but not
> used
> -I/usr/include              epplib.c -o epplib.o
> ar rc libmap.a mapbits.o maphash.o mapshape.o mapxbase.o mapparser.o
> maplexer.o maptree.o mapsearch.o mapstring.o mapsymbol.o mapfile.o
> maplegend.o maputil.o mapscale.o mapquery.o maplabel.o maperror.o
> mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o mappostgis.o
> maplayer.o mapresample.o mapwms.o mapwmslayer.o maporaclespatial.o
> mapgml.o mapprojhack.o epplib.o
> ranlib libmap.a
> -I/usr/include              shp2img.c -o shp2img.o
