[Mapserver-users] No help from developers regarding configure/com pile issues?
Madere, Colin colin.madere at ieminc.com
Tue Feb 18 15:53:15 EST 2003
Are there no developers reading this list?
I'm asking since I brought up (what would seem to me) a serious 'configure'
issue regarding compiling in support for MapScript many days ago and have
received zero response.
Here's a copy of my original message in case it was lost somehow:
Sol 8 - SPARC
gcc 3.2
When building mapserver with MapScript support:
./configure --with-postgis --with-gd --enable-force-freetype1
--with-php=/spool/build/php-4.3.0 --with-proj --with-wmsclient --with-gdal
I get the following error when running make:
make[1]: Entering directory `/spool/build/mapserver-3.6.4/mapscript/php3'
cc -xO3 -xdepend   -I. -I.. -KPIC -O2  -Wall -DCOMPILE_DL=1 -DPHP4
-DUSE_WMS_LYR -DUSE_WMS  -DUSE_GDAL     -DUSE_PROJ -DUSE_PROJ_API_H
-DUSE_EPPL -DUSE_TIFF   -DUSE_GD_PNG -DUSE_GD_WBMP -DUSE_GD_FT
-I/spool/build/mapserver-3.6.4 -I/usr/local/include
-I/usr/local/include/w3c-libwww -DHAVE_CONFIG_H  -I/usr/local/include
-I/usr/local/include   -I/spool/build/php-4.3.0 -I/spool/build/php-4.3.0/dl
-I/spool/build/php-4.3.0/main -I/spool/build/php-4.3.0/Zend
-I/spool/build/php-4.3.0/include -I/spool/build/php-4.3.0/TSRM  -c -o
php_mapscript_util.o php_mapscript_util.c
make[1]: cc: Command not found
make[1]: *** [php_mapscript_util.o] Error 127
make[1]: Leaving directory `/spool/build/mapserver-3.6.4/mapscript/php3'
Even though gcc is found (and even setting the env var CC to gcc doesn't
help), this error occurs.  Replacing "cc" manually with "gcc" gives errors
because the compiler switches are different (I would guess).
Any idea why this subdir is apparently not being included in the configure
to use the appropriate compiler and options?
Anyone know how to manually change this compiler execution with a working
one for gcc?
