[Mapserver-users] No help from developers regarding configure /com pile issues?
Madere, Colin colin.madere at ieminc.com
Tue Feb 18 16:48:25 EST 2003
So I'm not misunderstood, I'm not complaining or trying to make trouble, I
was just trying to get a feel for how this list operates and who reads it
and how the devs are involved (different for every project list I'm on).
I'll check out that issue, though I have manually changed the post-configure
makefile in that directory to read "gcc" rather than "cc" but it doesn't
work due to complier option differences.
It would be the problem of configure generating the correct options for gcc,
rather than what it's doing now which is generating the Makefile for cc.
I am using the latest release (3.6.4)
I did search for my problem in the list archives, but since many people say
it's been addressed before I may have been searching for it incorrectly
somehow since I didn't find anything.  Will try again.
Thanks for the input.
Colin
> -----Original Message-----
> From:	Jean-Francois.Doyon at CCRS.NRCan.gc.ca
> [SMTP:Jean-Francois.Doyon at CCRS.NRCan.gc.ca]
> Sent:	Tuesday, February 18, 2003 3:05 PM
> To:	colin.madere at ieminc.com
> Subject:	RE: [Mapserver-users] No help from developers regarding
> Colin,
> Hmmm, I thought that problem had disappeared since I haven't run into it
> lately ...
> The problem is in the Makefile of the PHP module, in mapscript/php3 ...
> Edit the Makefile, look for the "CC=" line, and remove the extra instance
> of
> "cc" that should be in there.
> I don't know if that was ever fixed ... there was talk about it being a
> problem with configure itself ...
> Also, which version of mapserver is it? Maybe this was fixed in the newer
> versions? I used to suffer from this too, but the problem disappeared on
> it's own, never really knew what was causing it.
> BTW, I'm NOT a developper, and yes they do read this list ... then again
> this was answered many times over, and the solution can therefore be found
> in the mailing list archives.
> J.F.
> From: Madere, Colin [mailto:colin.madere at ieminc.com]
> Sent: Tuesday, February 18, 2003 3:53 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] No help from developers regarding
> configure/com pile issues?
> Are there no developers reading this list?
> I'm asking since I brought up (what would seem to me) a serious
> 'configure'
> issue regarding compiling in support for MapScript many days ago and have
> received zero response.
> Here's a copy of my original message in case it was lost somehow:
> Sol 8 - SPARC
> gcc 3.2
> When building mapserver with MapScript support:
> ./configure --with-postgis --with-gd --enable-force-freetype1
> --with-php=/spool/build/php-4.3.0 --with-proj --with-wmsclient --with-gdal
> I get the following error when running make:
> make[1]: Entering directory `/spool/build/mapserver-3.6.4/mapscript/php3'
> cc -xO3 -xdepend   -I. -I.. -KPIC -O2  -Wall -DCOMPILE_DL=1 -DPHP4
> -DUSE_WMS_LYR -DUSE_WMS  -DUSE_GDAL     -DUSE_PROJ -DUSE_PROJ_API_H
> -DUSE_EPPL -DUSE_TIFF   -DUSE_GD_PNG -DUSE_GD_WBMP -DUSE_GD_FT
> -I/spool/build/mapserver-3.6.4 -I/usr/local/include
> -I/usr/local/include/w3c-libwww -DHAVE_CONFIG_H  -I/usr/local/include
> -I/usr/local/include   -I/spool/build/php-4.3.0
> -I/spool/build/php-4.3.0/dl
> -I/spool/build/php-4.3.0/main -I/spool/build/php-4.3.0/Zend
> -I/spool/build/php-4.3.0/include -I/spool/build/php-4.3.0/TSRM  -c -o
> php_mapscript_util.o php_mapscript_util.c
> make[1]: cc: Command not found
> make[1]: *** [php_mapscript_util.o] Error 127
> make[1]: Leaving directory `/spool/build/mapserver-3.6.4/mapscript/php3'
> Even though gcc is found (and even setting the env var CC to gcc doesn't
> help), this error occurs.  Replacing "cc" manually with "gcc" gives errors
> because the compiler switches are different (I would guess).
> Any idea why this subdir is apparently not being included in the configure
> to use the appropriate compiler and options?
> Anyone know how to manually change this compiler execution with a working
> one for gcc?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
