[Mapserver-users] Can't seem to get the projection correct
Martin, Daniel DMartin at erac.com
Tue Feb 18 17:35:44 EST 2003
Daniel & Ed, you were right on.  "UNITS dd" was the culprit.
Okay, I'm set up and perfect.  Everything is lovely.  Thanks to everyone for
their input today.  I'm a happy man.
-Dan Martin
> -----Original Message-----
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Tuesday, February 18, 2003 4:32 PM
> To: Martin, Daniel
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Can't seem to get the
> projection correct
> "Martin, Daniel" wrote:
> > The result is definitely what I was looking for.
> Everything looks perfect
> > except my scalebar is now doing some CRAZY stuff.  Does
> reprojection ruin
> > the scalebar?  I've attached two examples.
> Make sure your map UNITS are set to the units of the output
> projection,
> probably meters in this case.
>  Daniel Morissette               morissette at dmsolutions.ca
>  DM Solutions Group              http://www.dmsolutions.ca/
