[Mapserver-users] Browser anomalies
Martin, Daniel DMartin at erac.com
Wed Feb 19 16:42:33 EST 2003
Rob,
If this issue is that some browsers having problems with your querystrings,
you might troubleshoot this by switching your form tag to use method="post".
Worth a try, and couldn't hurt.  It would be interesting to see if the
problem still occurs.
-Dan
> -----Original Message-----
> From: Robert Stanton [mailto:geosys at iafrica.com]
> Sent: Wednesday, February 19, 2003 11:45 AM
> To: Mapserver users; Michael Schulz
> Subject: Re: [Mapserver-users] Browser anomalies
> Hi Michael
> I'm not using any Javascript on my pages
> Robert
> ----- Original Message -----
> From: "Michael Schulz" <mschulz at webgis.de>
> To: "Robert Stanton" <geosys at iafrica.com>
> Cc: "Mapserver users" <mapserver-users at lists.gis.umn.edu>
> Sent: Wednesday, February 19, 2003 4:19 PM
> > Hi,
> > a while ago i had a similar problem. In my case the problem with the
> message
> > "msQueryByPoint(): Search returned
> > no results. No matching record(s) found." came from the
> fact, that younger
> Gecko
> > engines (i.e. Netscape 7, Mozilla 1, etc.) did not submit
> the img.x /
> img.y
> > values to mapserv-cgi. The problem was related to that
> fact, that i used a
> > javascript onSubmit routine and the function that was
> called was enclosed
> by
> > <script>...</script> - after changing that to <script
> > language="JavaScript">...</script> it worked - for me.
> > HTH, Michael
> > Robert Stanton schrieb:
> > > Hi List
> > > I am experiencing a strange problem whereby a query template only
> appears in
> > > certain browsers and returns the error:  "msQueryByPoint(): Search
> returned
> > > no results. No matching record(s) found." in others. I am
> querying a
> point
> > > layer in cgi mode (gif output) using version 3.6.2 on RH
> Linux 7.2.
> > > The browsers that work are IE 6.0 and Opera 6.0 on
> Windows and Netscape
> 4.78
> > > on Linux. The ones that don't work are Mozilla 1.0.1 and
> Netscape 6.1 on
> > > Windows, and Mozilla 0.9 and Konqueror 2.2 on Linux. I
> have noticed that
> the
> > > ones that work all send the img.x and img.y values near
> the end of the
> query
> > > string, whereas the ones that don't work send the values near the
> beginning
> > > of the query string. I have put two examples at the end
> of this message.
> > > btw. the main template works fine in all browsers.
> > > I have tried the obvious such as increasing the
> 'Tolerance' value in the
> > > layer object to ridiculous levels, without success. I
> have also searched
> the
> > > archives, similarly without success. Unfortunately I
> cannot put these on
> the
> > > web just yet as they are still under development on my
> local intranet.
> > > Has anyone seen this problem before? Any advice would be extremely
> welcome.
> > > Robert Stanton
> > > Durban
> > > South Africa
> > > (btw. Many thanks to Frank Warmerdam, Ed McNierney,
> Kieran Ames, Steve
> > > Woodbridge and others who replied to a problem I had in
> late January
> > > concerning hyperlinks on output pages. I experienced a
> disk crash at
> about
> > > that time and was unable to reply)
> > > Examples of query string: (slightly reformatted)
> > > Windows - Mozilla 1.0.1 - ERROR:
> > > http://192.168.1.10/cgi-bin/mapserv/mapserv_362?
> > > img.x=184
> > > &img.y=229
> > > &mode=query
> > > &zoom=1
> > > &imgxy=249.5+199.5
> > > &imgext=28.864952+-29.384614+31.535048+-27.250000
> &map=%2Fhome%2Ftkzn%2Fpublic_html%2Fmaps%2Fbattlefields%2Fbtfl
> ds_362.map
> > > &scale=1682065.472443
> > > &savequery=true
> > > &mapext=shapes
> > > Windows - IE 6.0:
> > > mode=query
> > > &zoom=1
> > > &imgxy=249.5+199.5
> ds_362.map
> > > &savequery=true
> > > &mapext=shapes
> > > &img.x=184
> > > &img.y=229
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > Michael Schulz                                in medias res
> > Dipl.-Geologe                              Gesellschaft für
> >                                 Informationstechnologie mbH
> >                              Sautierstr. 38, 79104 Freiburg
> >                                      0761 55695-95 (Fax 96)
> > mschulz at webgis.de                             www.webgis.de
