[Mapserver-users] How to label points with attributes from Mysql-DB
James Jefferson jjeffers at aprsworld.net
Fri Feb 14 19:09:57 EST 2003
I wrote a program called mysql2shp that lets you do a MySQL query and generate
a shapefile. I actually am using it for plotting weather with mapserver, too.
Here is an example:
mysql2shp -hlocalhost -uUSERNAME -pPASSWORD -dDATABASE /tmp/wind "SELECT
lastposition.longitude,lastposition.latitude,0,lastweather.wind_speed AS
wspeed,lastweather.wind_direction AS wdir,lastweather.source FROM
lastweather,lastposition WHERE lastweather.wind_speed != '\n' AND
lastweather.source=lastposition.source"
It can be downloaded from:
http://sourceforge.net/projects/aprsworld/
-Jim
