[Mapserver-users] dynamic libraries and LDPATH
Madere, Colin colin.madere at ieminc.com
Fri Feb 21 17:37:24 EST 2003
You know, you 'd have thought I'd have run across that Apache SetEnv
directive.. was looking for exactly that a few weeks ago and didn't find it.
Or rather, someone I asked to find it didn't find it :)
SetEnv gets me running!  Thanks for the input.  I haven't tried the
--enable-runpath, what does that do compared to setting the -Wl, compiler or
-R linker flags?  Or does it simply enable them without editing the
makefiles?
Now I'm getting an error with MapLab and the requirement of dbase.so, which
I don't have and don't know where it's from.  Install docs from MapLab say
nothing about it!  Posted to MapLab list... hope they are as helpful as you.
Thanks again,
Colin
> -----Original Message-----
> From:	Daniel Morissette [SMTP:morissette at dmsolutions.ca]
> Sent:	Friday, February 21, 2003 2:00 PM
> To:	Madere, Colin
> Cc:	mapserver-users at lists.gis.umn.edu
> Subject:	Re: [Mapserver-users] dynamic libraries and LDPATH
> "Madere, Colin" wrote:
> > So I get an error trying to use Mapscript because when the .so is loaded
> by
> > PHP it can't find the libwwwxml.so.0 (turning error output on shows the
> > typical ld.so error when it can't find a library).
> Sounds like libwwwxml.so is not in your runtime library path.  On Linux
> the solution is to rerun /sbin/ldconfig after making sure that
> /usr/local/lib is listed in your /etc/ld.so.conf, but since you're on
> Solaris I'm not sure what's the best way to update the runtime libpath.
> > So I found out that setting LDFLAGS = -R<location of libs> would
> instruct
> > the linker to link in the library paths so that runtime resolution
> wasn't
> > necessary.
> Try adding --enable-runpath to the MapServer configure, it should do
> that for you.
> > I've got mapserv CGI to run by wrapping it in a shell script that sets
> > LD_LIBRARY_PATH for the .so it was looking for, however, with PHP and
> > Mapscript it is a .so that loads a .so that loads a .so :)
> LD_LIBRARY_PATH
> > is not a solution there so I have to figure out how to get the linker to
> set
> > the paths to the shared objects that the php_mapscript.so needs.
> Assuming that you're using Apache, you could use the SetEnv directive in
> your httpd.conf to do that.
> BTW, you seem to suggest that you are using PHP configured as an Apache
> DSO... you need PHP configured as a CGI, see:
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI
> Yes I know, it's complicated, and Solaris isn't the most friendly
> platform I would have to admit.
> Daniel
>  Daniel Morissette               morissette at dmsolutions.ca
>  DM Solutions Group              http://www.dmsolutions.ca/
