[Mapserver-users] Raster: rotation params in WLD file
Frank Warmerdam
warmerdam at pobox.com
Sat Feb 22 14:10:58 EST 2003
Lars V. Nielsen wrote:
> Hi Frank,
> Indeed it doesn't, it simply ignores the secondar parameters completely (I
> have tried).
>> ..., but if you handle a raster through GDAL in MapServer then it can be
>> rotated properly to display in MapServer.
> Does this mean that I can use e.g. the below output format spec in 3.7 to
> display rotated raster images ?
Lars,
Actually, it's not the output side that is the issue, but the input side.
Also, you need to attach projections to the map and layer in question to
"trick" it into doing a reprojection that isn't really changing projection.
Try setting a projection on the map and layer, and see what happens. Any
projection should do as long as it matches but accurate would be best.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
