[Mapserver-users] MapServer & Tomcat
Matthew Hatcher MJHatcher at space.qinetiq.com
Mon Feb 24 04:58:54 EST 2003
Stefan,
Tomcat is used for Java servlets, whilst the Mapserver EXE is a standard CGI
application. You should find a "cgi-bin" folder in your Apache folder (I
presume you're using Windows, as you refer to mapserv.exe) which will be in
Program Files\Apache Group\Apache. Put the file in there and try
http://localhost/cgi-bin/mapserv.exe
Alternatively, you can put it into another folder and in your httpd.conf
file use either the ScriptAlias or Options +ExecCGI tags. See
http://httpd.apache.org/docs/howto/cgi.html#configuringapachetopermitcgi for
more details.
Matt.
-----Original Message-----
From: Kaps Stefan [mailto:0098kast at edu.fh-kaernten.ac.at]
Sent: 24 February 2003 09:46
To: 'mapserver-users at lists.gis.umn.edu'
Subject: [Mapserver-users] MapServer & Tomcat
Hello!
I'm using mapserver with apache tomcat webserver, but there does not exist a
cgi-bin directory ... i don't know where to put the mapserv.exe file!
perhaps there are also tomcat-users out there.
stefan
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
The information contained in this email and any subsequent
 correspondence is private and is intended solely for the
intended recipient(s). For those other than the intended
 recipient(s) any disclosure, copying, distribution, or any
action taken or omitted to be taken in reliance on such
information is prohibited and may be unlawful.
