[Mapserver-users] MapServer & Tomcat
Martin, Daniel DMartin at erac.com
Mon Feb 24 10:45:57 EST 2003
Actually Tomcat can be run stand-alone outside of Apache.  If this is how
you are using it Stefan, CGI is still available.  See this HOW-TO:
http://jakarta.apache.org/tomcat/tomcat-4.1-doc/cgi-howto.html
-Dan Martin
> -----Original Message-----
> From: Matthew Hatcher [mailto:MJHatcher at space.qinetiq.com]
> Sent: Monday, February 24, 2003 3:59 AM
> To: 'Kaps Stefan'; 'mapserver-users at lists.gis.umn.edu'
> Subject: RE: [Mapserver-users] MapServer & Tomcat
> Stefan,
> Tomcat is used for Java servlets, whilst the Mapserver EXE is
> a standard CGI
> application. You should find a "cgi-bin" folder in your
> Apache folder (I
> presume you're using Windows, as you refer to mapserv.exe)
> which will be in
> Program Files\Apache Group\Apache. Put the file in there and try
> http://localhost/cgi-bin/mapserv.exe
> Alternatively, you can put it into another folder and in your
> httpd.conf
> file use either the ScriptAlias or Options +ExecCGI tags. See
> http://httpd.apache.org/docs/howto/cgi.html#configuringapachet
opermitcgi for
more details.
Matt.
From: Kaps Stefan [mailto:0098kast at edu.fh-kaernten.ac.at]
Sent: 24 February 2003 09:46
To: 'mapserver-users at lists.gis.umn.edu'
Subject: [Mapserver-users] MapServer & Tomcat
Hello!
I'm using mapserver with apache tomcat webserver, but there does not exist a
cgi-bin directory ... i don't know where to put the mapserv.exe file!
perhaps there are also tomcat-users out there.
stefan
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
The information contained in this email and any subsequent
 correspondence is private and is intended solely for the
intended recipient(s). For those other than the intended
 recipient(s) any disclosure, copying, distribution, or any
action taken or omitted to be taken in reliance on such
information is prohibited and may be unlawful.
