[Mapserver-users] dynamic libraries and LDPATH
Daniel Morissette morissette at dmsolutions.ca
Tue Feb 25 14:06:23 EST 2003
"Madere, Colin" wrote:
> Where does configure get the value for the runpath when this option is used?
> Now I'm manually setting it by adding the -R to two directories where I have
> libraries (one for general and another for pgsql).
It takes it from the path where it found libraries for which you
specified an explicit path. For instance, if you specify
'--with-gd=/usr/local --enable-runpath' then it should add
-R /usr/local/lib
 DM Solutions Group              http://www.dmsolutions.ca/
