[Mapserver-users] Layer question
Eric Bridger eric at gomoos.org
Wed Feb 26 06:36:06 EST 2003
Yes.Layers are displayed FIFO. The first layer in the map file is
displayed first, subsequent layers on top of the preceeding ones. So
your raster should be first in the map file, points after.  I think this
is also true as layers passed as CGI parameters to mapserv, so e.g. if
you have a SELECT list of layers in your form, put the raster layer
above the point layer, so you get layer=relief&layer=points.
On Wed, 2003-02-26 at 15:53, Kevin Slover wrote:
> I remember seeing documented somewhere that there layers are displayed
> in a certain format.. i.e. first in/first out?  I cannot seem to find
> this documentation anywhere...
> My problem is that I am wanting to display point data on top of a
> "raster" layer, i.e. city locations over urban areas.  I am using java
> if that makes a difference...
> Thanks, cheers!
> LTJG Kevin Slover, NOAA
> GIS Specialist/Oceanographer
> NOAA/National Hurricane Center/Storm Surge Unit
> 11691 SW 17th Street
> Miami FL  33165
> W (305) 229-4456
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
