[Mapserver-users] MapScript, help starting?
Junkmail Box
junkmail at deathkeep.com
Thu Feb 27 11:33:35 EST 2003
I'm having trouble getting started using Perl MapScript. The doc at
http://mapserver.gis.umn.edu/doc36/perlmapscript-reference.html doesn't
give a lot for examples of getting started. They do give this, though:
#!/usr/bin/perl
use mapscript;
my $map = new mapObj('arcata.map') or die('Unable to open mapfile.');
my $img = $map->draw() or die('Unable to draw map');
my $void = $img->saveImage('example.png', $mapscript::MS_PNG, $map->{transparent}, $map->{interlace}, 0);
However, when I run it, example.png is an empty file.
Any ideas on what the problem could be?
Are there any tutorials on getting started using MapScript?
arcata.map is a map file, and works with the mapserv CGI binary just fine.
And $map->{numlayers} properly says there are 3 layers in the map. So I
know mapscript is seeing the arcata.map file, and that arcata.map is
valid. The arcata.map file is as follows:
# map file - Arcata demo
NAME ARCATADEMO
STATUS ON
SIZE 504 504
EXTENT 407375 4522866 410627 4526910
UNITS METERS
SHAPEPATH "/usr/local/mapserv/htdocs/arcata"
IMAGECOLOR 255 255 255
IMAGETYPE JPEG
# web interface definition
WEB
# the template for browsing mode
TEMPLATE arcata.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "/usr/local/mapserv/tmp/"
IMAGEURL "/tmp/"
END
# reference (thumbnail) map
REFERENCE
EXTENT 404958.660383 4520848.011905 413035.327051 4528936.011905
SIZE 216 216
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
## legend - automatically generated from any classes that have a NAME
attribute
#LEGEND
# KEYSIZE 18 12
# LABEL
# TYPE BITMAP
# SIZE MEDIUM
# COLOR 0 0 89
# END
# STATUS ON
#END
# scalebar
SCALEBAR
IMAGECOLOR 0 0 0
LABEL
COLOR 255 255 255
SIZE medium
END
STYLE 1
SIZE 288 6
COLOR 255 255 255
UNITS MILES
INTERVALS 4
TRANSPARENT TRUE
STATUS ON
END
### LAYER DEFINITIONS
### parcel divisions
LAYER
NAME parcels
TYPE POLYGON
DATA parcels
STATUS OFF
# what template to use for displaying a query about a parcel
TEMPLATE /usr/local/mapserv/htdocs/arcata/parcel_query_template.html
# when labeling parcels, the owner's name is the label to use
LABELITEM OWNER_NAME
# color-code certain parcels, depending on the owner
CLASSITEM OWNER_ADD
CLASS
#EXPRESSION "ARCATA PLAZA"
EXPRESSION /ARCATA*/
COLOR 128 255 255
OUTLINECOLOR 0 255 0
LABEL
COLOR 0 0 0
END
END
CLASS
EXPRESSION /CALIFORNIA*/
COLOR 200 200 200
LABEL
COLOR 0 0 0
END
END
# default parcel coloration
CLASS
NAME "Parcel"
COLOR 255 120 120
LABEL
COLOR 255 255 255
END
END
END
### creeks
LAYER
NAME creeks
STATUS OFF
DATA creeks
TYPE LINE
CLASS
NAME "Creek"
COLOR 0 0 255
END
# template to use if someone queries a creek
TEMPLATE creeks_query_template.html
END
### roads
LAYER
NAME roads
STATUS ON
DATA roads
TYPE LINE
CLASS
NAME "Road"
COLOR 0 0 0
LABEL
COLOR 128 128 128
END
END
# label roads, and allow a user to query a road
LABELITEM FNAME
TEMPLATE roads_query_template.html
END
### END OF LAYER DEFINITIONS
END # end of map file
