[Mapserver-users] Troubles with shapefiles
Paul Ramsey
pramsey at refractions.net
Fri Feb 28 12:25:17 EST 2003
You have a number in your shapefile which is larger than int32
representation can hold. The latest shp2pgsql in the CVS archive
includes support for all these large nasty numbers, just download and
compile the cvs snapshot.
P.
Alessandro Ceccotti wrote:
> Hello, I've got a problem using mapserver:
> I've to insert a .shp file in my postgis db. I use shp2pgsql to create a
> .psql file then, when I go to insert it in my database, it gives me the
> following error:
> 4: ERROR: pg_atoi: error reading "30390019695586": Numerical result out
> of range
> NOTICE: current transaction is aborted, queries ignored until end of
> transaction block
> It creates all the tables in db, but not populate it.
> On what may be due to?
> Thanks,
> Ing.Alessandro Ceccotti.
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
