[Mapserver-users] rotating labels move away from label point ??
George Planansky
george_planansky at NOSPAMharvard.edu
Tue Jan 7 21:41:00 EST 2003
Using ANGLE to rotate labels, as below,
we expected to see the label string
rotate propeller-fashion around the
label point (which is in the center
of our polygons and shows up as we
expect).
However, the labels instead move away from
the label point as we change the rotation
angle. The longer the label string, the
further away they move.
We don't understand this -- what is
happening here? How do we keep
the label string centered on the label point.
CLASS
COLOR -1 -1 -1
COLOR 255 0 0
SYMBOL 'circle'
SIZE 5
LABEL
POSITION CC
ANGLE 135.00
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 14
ANTIALIAS TRUE
PARTIALS FALSE
BUFFER 2
END
END
Thanks
George Planansky
