[Mapserver-users] mapscript and XBase cause Out of memoryerrorand/or
premature endof script headers error
Daniel Morissette
morissette at dmsolutions.ca
Thu Jan 9 20:46:55 EST 2003
"Jonathan W. Lowe" wrote:
> The rest of the story is still not over, however. The test script that now
> works is only a test script; the main script still fails, with a "Premature end
> of script headers" error message in the log file. I plan to slowly add
> subroutines to the working script and see where it stops working...
FYI we have run into a similar issue on a Linux box where a Perl
MapScript (3.6.x) script would work fine at the command line but would
sometimes crash in the web server environment just after the call to
$map->draw(), resulting in a premature end of script headers (or
truncated output sometimes)... I have never been able to identify the
source of the problem, but if you find anything then I would be very
interested in hearing the solution.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
