[Mapserver-users] TrueType Font and Label Angle
Ellenbecker, Larry
LEllenbecker at co.winnebago.wi.us
Mon Jan 13 11:03:20 EST 2003
List,
I'm trying to get true type fonts working with my application on Linux. The
application is up a running on both Linux and NT. True type fonts are
working just fine on NT, but on Linux I've had the following problems. My
application is straight CGI.
System Specs: RedHat 7.0 with freetype-1..3.1. freetype-2.1.2, gd-2.0.9
and mapserver-3.6.1.
After compiling and installing both freetype fonts and GD,
I compiled mapsever and got the msGetLabelSize(): Could not find/open font.
Initaially my application was sitting at:
/var/www/html/simple with simple.map FONSET
fonts/fonts.txt
When I moved my fonts directory to /var/www/html/fonts and
changed simple.map FONSET ../fonts/fonts.txt I was able to use true type
font arial in my application. I then ran into the next issue with Label
Angle. I couldn't get the labels to follow the appropriate line orientation
as it does on my NT version. I researched the list and found Jonathan
Lowe's "line layer label angle changes(solved)" . I've tried to follow
these directions but am still unable to get the labels to plot with the
correct orientation of the line. The BUFFER, BACKGROUNDSHADOWSIZE AND
BACKGROUNDCOLOR create a background box oriented in the appropriate
position but the text doesn't hit the background box.
Has anyone got a sure fire method for resolving truetype
label angle problems - I'd sure appreciate any assistance.
Larry L. Ellenbecker
GIS Systems Analyst
Winnebago County
